WCrihfield
in reply to: b.mccarthy
Hi @b.mccarthy.  I created a different iLogic rule that should meet your needs better.  I added tons of comments in there to help you understand everything that is going on.  It is in the attached text file.  You will need to edit the names of the external iLogic rule names in Lines 10, 11, & 12.  If you need to add more external rule names, just duplicate one of those 3 Lines, then change the rule name in the new line to what you want.  Or, if you need fewer rule names, just delete one of those 3 Lines, or add an apostrophe (') at the left (start) of one of those lines of code to 'comment it out'.  You should not need to edit anything else in the code.
Let me know how this works for you.
Wesley Crihfield
(Not an Autodesk Employee)
