A.Acheson
in reply to: breinkemeyer
Hi @breinkemeyer
Yes that would be a good way to tie a centerline to the model. You can also project a curve into the sketch and constrain the line to that curve.
Here is a quick sample in VB.NET of just adding a sketchline and changing layer to Centerline.
Dim drawView As DrawingView = ThisApplication.CommandManager.Pick(SelectionFilterEnum.kDrawingViewFilter, "Select a drawing view")
Dim drawDoc As DrawingDocument= ThisApplication.ActiveDocument
Dim sketch1 As DrawingSketch = drawView.Sketches.Add
sketch1.Edit
Dim startPt As Point2d = ThisApplication.TransientGeometry.CreatePoint2d(0,0)
startPt = drawView.SheetToDrawingViewSpace(startPt)
Dim endPt As Point2d = ThisApplication.TransientGeometry.CreatePoint2d(216*2.54,0)
endPt = drawView.SheetToDrawingViewSpace(endPt)
Dim oLine As SketchLine = sketch1.SketchLines.AddByTwoPoints(startPt, endPt)
Dim layers As LayersEnumerator = drawDoc.StylesManager.Layers
oLine.Layer = layers.Item("Centerline (ANSI)")
sketch1.ExitEdit
This isn't tied to any specific geometry, the centerline is just of the sheet.
Regards
Alan
