OK @k.dossantosFGLW2.  I will attach a text file to this response which will contain some code that you can use as an iLogic rule.  It is rather long, so posting it within an attached text file is more convenient for both of us.  Review the code before running it.  This code could be used either as an external, or internal iLogic rule itself, and can also be used to add either an internal, or external iLogic rule to the Event Triggers dialog, on the 'This Document' tab only, and is currently set-up for that one specific event 'Before Save'.  Not sure how familiar you are with this process, but each different event has its own 'internal' name that is different from what you see within the Event Triggers dialog.  And each different event has its own range of PropID values that must be used just for that event.  I will also attach my Excel file containing the chart/table of what those internal event names are and what their PropID ranges need to be.  This data should be accurate for the initial release of Inventor version 2024, but might not be 100% inclusive for later updates of Inventor.  Give these a try, and let me know how it works for you.
Wesley Crihfield
(Not an Autodesk Employee)
