Hi @k.dossantosFGLW2.  Yes, this may be possible, but we would need to know more about this task from you to be sure.  But it can be a relatively complex process.  Have you searched within this forum yet for what you want?  When I search this forum for that topic, I get many results.  I have been involved in many of those discussions.  There is a lot of good information among those other forum posts about this topic, many of which have been solved, and contain example codes as solutions.
Which tab within the Event Triggers dialog do you want to add this rule within (All Documents, Parts, Assemblies, Drawings, This Document)?
Is the rule that you want to add to the Event Triggers an internal rule (saved within an Inventor document) or an external rule?
Wesley Crihfield
(Not an Autodesk Employee)
