Preston_Reed
in reply to: aflores9JTPA
here you go, i briefly tested it, it should be working ok.  Let me know if you have any issues
Sub main
	iPropPartNumbers
End Sub
Sub iPropPartNumbers
	Dim oAsmCompDef As AssemblyComponentDefinition
	oAsmCompDef = ThisApplication.ActiveDocument.ComponentDefinition
''' Sub Asm
	' Iterate through all Of the occurrences
	Dim oOccurrence As ComponentOccurrence
	For Each oOccurrence In oAsmCompDef.Occurrences.AllReferencedOccurrences(oAsmCompDef)
		' Searching through the top level assembly file in order to locate only sub assembly files
		If oOccurrence.DefinitionDocumentType = kAssemblyDocumentObject Then
			comp = Component.InventorComponent(oOccurrence.Name)
			Dim CompStrng As String = oOccurrence.Name
            ' Split the string using ":" as delimiter and get the first element
            Dim NewName As String = CompStrng.Split(":")(0)
					' Create iprop with PS Value
					iProperties.Value("Project", "Part Number") = NewName
			' Write to component iprops
			On Error Resume Next
			iProperties.Value(oOccurrence.Name, "Project", "Part Number") = _
		Else
		End If
	Next
''' Piece Parts
		If oOccurrence.DefinitionDocumentType = kPartDocumentObject Then
		Else
		End If
	Next
End Sub
