ndillner343SKL
277 Views, 3 Replies
Copy Styles From Template File
Good Afternoon,
I'm trying to copy styles from a template file and add/update the local styles.
I found similar code written by @WCrihfield and tweaked it to be what I'm looking for. But it doesn't appear to be overriding the existing styles.
Reference:
https://forums.autodesk.com/t5/inventor-programming-ilogic/ilogic-to-load-a-style-in-templates-autom...
Dim oTDDoc As DrawingDocument = ThisApplication.Documents.Open(oTFN, False)
Dim oTStylesMgr As DrawingStylesManager = oTDDoc.StylesManager
Dim oStylesMgr As DrawingStylesManager = oDDoc.StylesManager
Dim oStyle As Style
For Each oTStyle As Style In oTStylesMgr.Styles
	MsgBox(oTStyle.Name)
	If oTStyle.StyleLocation = StyleLocationEnum.kLibraryStyleLocation Then
		oTStyle.ConvertToLocal
	ElseIf oTStyle.StyleLocation = StyleLocationEnum.kBothStyleLocation Or _
		   oTStyle.StyleLocation = StyleLocationEnum.kLocalStyleLocation Then
		oStyle = oStylesMgr.Styles.Item(oTStyle.Name)
		Dim oTSCol As ObjectCollection = ThisApplication.TransientObjects.CreateObjectCollection
		oTSCol.Add(oTStyle)
		oTStylesMgr.ReplaceStyles(oTSCol, oStyle, True)
	End If
Next
