04-02-2024
07:15 AM
- Mute
- Permalink
- Report
04-02-2024
07:15 AM
Hey, I've already got all the parts in the assembly so I just need to run the iLogic rule once. And the instance wouldn't be needed since the display file names are already set. The reason I don't need instance numbers is because I've got a lot of parts and the duplicates should have the same part number so I get a quantity in the BOM automatically.
I had found this post where some code was made to take the filename and make it the part name for every part in an assembly. this is very similar to I want but I just need to alter the code where instead of taking the Filename it takes the Display name and makes that the part number.
https://forums.autodesk.com/t5/inventor-forum/automatic-setting-filename-to-partnumber/td-p/6819654
