aflores9JTPA
525 Views, 5 Replies
Rename Part numbers into the Display names of parts in an assembly
I'm wanting to take the Display names of parts and have those names be the part numbers for all the parts in my assembly. I've looked through other forums to try to see if I can bring some iLogic code together but I'm new to it and was unsuccessful. Any ideas on how to easily do this?
James_Willo
in reply to: aflores9JTPA
Hi, I assume you mean the name plus the instance number?        "Plate:1"
Yes I think iLogic would be the only way to do this, but you would need to run the code every time a new part was added.
James W
Inventor UX Designer
aflores9JTPA
in reply to: James_Willo
Hey, I've already got all the parts in the assembly so I just need to run the iLogic rule once. And the instance wouldn't be needed since the display file names are already set. The reason I don't need instance numbers is because I've got a lot of parts and the duplicates should have the same part number so I get a quantity in the BOM automatically.
I had found this post where some code was made to take the filename and make it the part name for every part in an assembly. this is very similar to I want but I just need to alter the code where instead of taking the Filename it takes the Display name and makes that the part number.
https://forums.autodesk.com/t5/inventor-forum/automatic-setting-filename-to-partnumber/td-p/6819654
Preston_Reed
There's 3 "Part Names", the file path (.ipt), occurrence (what you see in the model tree) & the part number (in iProperties).   So you want to change the part number into what the occurrence is?
aflores9JTPA
in reply to: Preston_Reed
yes id want the part number to be what the occurrence is without the occurrence value at the end. Here is an example of some of the occurrence names I've got and I marked it with what values I don't want on the part number.
Preston_Reed
here you go, i briefly tested it, it should be working ok.  Let me know if you have any issues
Sub main
	iPropPartNumbers
End Sub
Sub iPropPartNumbers
	Dim oAsmCompDef As AssemblyComponentDefinition
	oAsmCompDef = ThisApplication.ActiveDocument.ComponentDefinition
''' Sub Asm
	' Iterate through all Of the occurrences
	Dim oOccurrence As ComponentOccurrence
	For Each oOccurrence In oAsmCompDef.Occurrences.AllReferencedOccurrences(oAsmCompDef)
		' Searching through the top level assembly file in order to locate only sub assembly files
		If oOccurrence.DefinitionDocumentType = kAssemblyDocumentObject Then
			comp = Component.InventorComponent(oOccurrence.Name)
			Dim CompStrng As String = oOccurrence.Name
            ' Split the string using ":" as delimiter and get the first element
            Dim NewName As String = CompStrng.Split(":")(0)
					' Create iprop with PS Value
					iProperties.Value("Project", "Part Number") = NewName
			' Write to component iprops
			On Error Resume Next
			iProperties.Value(oOccurrence.Name, "Project", "Part Number") = _
		Else
		End If
	Next
''' Piece Parts
		If oOccurrence.DefinitionDocumentType = kPartDocumentObject Then
		Else
		End If
	Next
End Sub
