- Mute
- Permalink
- Report
The most important task is the first one:
1. When I edit the PDF template from Autodesk for 3d documents I cant get all the digits. There isnt enough room in the assembly template. I dont know if the problem is the PDF template from autodesk or if it is the Inventor.
2. When having the PDF printed for 3d models for creation date and checked date - I did get the value 2023-03-28 00:00:00. I dont want the time though. How do I remove the time 00:00:00?
For State, I got the Value 1, 2 or 3.
1 should be WorkInProgress, 2 should be Pending and 3 should be Released.
How to I change so that the value names should be written instead of numbers?
Also, I have one column for weight. {{{ topComponent.Mass || "" }}}
It writes a lot of numbers after decimal. Is it possible to change it so that no decimals are written?
Did it help? If not, please tell me what part was not detailed enough.
