k_ponomarenko
377 Views, 2 Replies
Creating a multi-valued parameter using ilogic.
Hello.
I have a code that allows you to create and delete a parameter.
But the problem is that when creating a parameter using code, it is created not as a multi-valued parameter, but as a single parameter. At the same time, the program does not issue any errors.
If I understand correctly, the logic of the ArrayList code is broken.
Please help me solve this problem.
Thank you.
'MultiValue.SetList("Capacity_Type", "Container CIP solutions", "Pressure_damping_capacity")
'Capacity_Type = "Container CIP solutions"
Dim oParams As Parameters
Dim oAssemblyDoc As AssemblyDocument = ThisDoc.Document
Dim oAssemblyCompDef As AssemblyComponentDefinition = oAssemblyDoc.ComponentDefinition
Dim oComp As AssemblyComponentDefinition = oAssemblyDoc.ComponentDefinition
oParams = oAssemblyCompDef.Parameters
Dim oUPs As UserParameters = oComp.Parameters.UserParameters
Dim oUP As UserParameter
Dim ParamName As String = "Diameter_of_the_intake_pipe"
Dim List As New ArrayList
	List.Add("80")
	List.Add("100")
	List.Add("125")
	List.Add("150")
If Capacity_Type = "Container CIP solutions" Then
	Try
		Test = oUPs.Item(ParamName).Value
	Catch
		oUP = oUPs.AddByExpression(ParamName, List.Item(3), UnitsTypeEnum.kMillimeterLengthUnits)
		Parameter("Container CIP:1", "Diameter_of_the_intake_pipe") = Parameter(ParamName)
	End Try
ElseIf Capacity_Type = "Pressure_damping_capacity" Then
	Try
		oUP = oUPs.Item(ParamName)
		oUP.Delete
	Catch
	End Try
	Parameter("Container CIP:1", "Diameter_of_the_intake_pipe") = False
End If
This is short code snippet to create new UserParamter with multi values
Dim partDef As PartComponentDefinition = ThisDoc.Document.ComponentDefinition
'Add new parameter as multi-value
Dim paramName As String = "TestParam"
Dim expressions As String() = {"1 mm", "2 mm", "3 mm" }
Dim newParam = partDef.Parameters.UserParameters.AddByExpression(paramName, "0", UnitsTypeEnum.kMillimeterLengthUnits)
newParam.ExpressionList.SetExpressionList(expressions, True, -1)
Walliguy
in reply to: k_ponomarenko
Hey there.
Looking at your code it looks likes in your try you are verifying "Diameter_of_the_intake_pipe" user parameter exists. If it doesn't (catch) then you want to create a new multivalue list user parameter.
In the AddByExpression method I believe you are just passing a single item in the list "List.Item(3)"
This is the pattern I took:
    Try
        Dim userParameter As UserParameter
        userParameter = userParameters.Item("STD_YES")
    Catch
        Dim UserParameter As UserParameter = userParameters.AddByValue("STD_YES", "No", "String")
        MultiValue.SetList("STD_YES", "Yes")
        UserParameter.IsKey = True
    End Try
Hope this helps,
Chris
