- Mute
- Permalink
- Report
Wishing everyone a great day!
I ask for advice on how to orient the text along the largest edge.
In wood processing there is a need to control wood grain texture vector in detail. For most of the details, I think the solution is to find the largest face of the detail. Then place the symbol indicating the direction of the material in the text box. The task has been partially solved.
Some examples of code were collected on the forum pages, which provided the following.
' Get the current details document
Dim oPart As PartDocument = ThisApplication.ActiveDocument
' Get the part component definition
Dim oCompDef As PartComponentDefinition = oPart.ComponentDefinition
'Initialize variables to store the largest face and its area
Dim maxFace As Face = Nothing
Dim maxArea As Double = 0.0
' Find the edge with the largest area
For Each oFace As Face In oCompDef.SurfaceBodies.Item(1).Faces
' Calculate the face area
Dim oAreaProps As Double
oAreaProps = oFace.Evaluator.Area
' Check whether the current face is the face with the largest area
If oAreaProps > maxArea Then
maxArea = oAreaProps
maxFace = oFace
End If
Next
' Create a sketch on the plane of the selected face
Dim oSketch As Sketch = oCompDef.Sketches.Add(maxFace)
' Find the face contour with index 1
Dim oEdgeLoop As EdgeLoop = maxFace.EdgeLoops(1)
' Find the minimum and maximum point of the bounding parallel
Dim oMinPt As Point = oEdgeLoop.RangeBox.MinPoint
Dim oMaxPt As Point = oEdgeLoop.RangeBox.MaxPoint
' Find the center of the bounding parallelepiped circuit
Dim CenterPt As Point = ThisApplication.TransientGeometry.CreatePoint((oMaxPt.X + oMinPt.X) / 2#, (oMaxPt.Y + oMinPt.Y) / 2#, (oMaxPt.Z + oMinPt.Z) / 2#)
' Let’s convert the coordinates of the center into the coordinates of the sketch
Dim oTextPt As Point2d = oSketch.ModelToSketchSpace(CenterPt)
'Add text "Largest face" to the sketch center
oText = "↔"
Dim oTextBox As TextBox = oSketch.TextBoxes.AddFitted(oTextPt, oText)
' Set new text height (centimeters)
oFontSize = 6
oTextBox.FormattedText = "<StyleOverride FontSize = '" & oFontSize & "'>" & oText & "</StyleOverride>"
oTextBox.HorizontalJustification = kAlignTextCenter
oTextBox.VerticalJustification = kAlignTextUpper
iLogicVb.UpdateWhenDone = TrueWhat are the ways to orient the text along the largest edge?
- Mute
- Permalink
- Report
Could you share some screenshots of the results you need? To see if there are simpler solutions
Please accept as solution and give likes if applicable.
I am attaching my Upwork profile for specific queries.
Sergio Daniel Suarez
Mechanical Designer
| Upwork Profile | LinkedIn
- Mute
- Permalink
- Report
to search the longest edge and rotate the TextBox use:
' search the longest edge Dim maxLen As Double Dim maxEdge As Edge For Each oEdge As Edge In oEdgeLoop.Edges eLen = ThisApplication.MeasureTools.GetMinimumDistance(oEdge.StartVertex.Point, oEdge.StopVertex.Point) If eLen > maxLen Then maxLen = eLen maxEdge = oEdge End If Next Dim oP1 As Point2d = oSketch.ModelToSketchSpace(maxEdge.StartVertex.Point) Dim oP2 As Point2d = oSketch.ModelToSketchSpace(maxEdge.StopVertex.Point) Ang = Atan((oP2.Y - oP1.Y) / (oP2.X - oP1.X)) ' rotate TextBox Dim oColl As ObjectCollection = ThisApplication.TransientObjects.CreateObjectCollection() oColl.Add(oTextBox) oTextBox.ShowBoundaries = True oSketch.RotateSketchObjects(oColl, oSketch.ModelToSketchSpace(CenterPt), Ang, False, True) Dim oHin As Vector2d = ThisApplication.TransientGeometry.CreateVector2d(1, 0) Dim oHer As Vector2d = ThisApplication.TransientGeometry.CreateVector2d(-1, 0) oSketch.MoveSketchObjects(oColl, oHin) oSketch.MoveSketchObjects(oColl, oHer)
- Mute
- Permalink
- Report
In my opinion the longest edge must not be the right edge.
It is better to use semi-automatic rule, which allows you to pick the edge you want to align text to and use GeometricalConstraints to align text to this projected edge.
Dim pick = ThisApplication.CommandManager.Pick(SelectionFilterEnum.kPartEdgeLinearFilter, "Pick the edge")
Dim edge As Edge = TryCast(pick, Edge)
If edge Is Nothing Then Return
Dim largestFace As Face = Nothing
Dim largestArea As Double = 0
For Each face As Face In edge.Faces
'Skip non-planar faces
If Not TypeOf (face.Geometry) Is Plane Then Continue For
If face.Evaluator.Area > largestArea Then
largestFace = face
largestArea = face.Evaluator.Area
End If
Next
'Return, when largest planar face wasn't found
If largestFace Is Nothing Then Return
Dim pointOnFace As Point = largestFace.PointOnFace
'Create sketch
Dim partDef As PartComponentDefinition = edge.Parent.ComponentDefinition
Dim sketch As PlanarSketch = partDef.Sketches.Add(largestFace)
Dim addByProjectingEntity As SketchEntity = sketch.AddByProjectingEntity(edge)
Dim textBox As Inventor.TextBox = sketch.TextBoxes.AddFitted(sketch.ModelToSketchSpace(pointOnFace), "<-->")
textBox.ShowBoundaries = True
sketch.GeometricConstraints.AddParallel(addByProjectingEntity, textBox.BoundaryGeometry(2))
