03-20-2024
03:44 PM
- Mute
- Permalink
- Report
03-20-2024
03:44 PM
This example creates a (very thin) box and aligns it with an edge that you selected.
Public Sub Main()
Dim oTg = ThisApplication.TransientGeometry
Dim edge As Edge = ThisApplication.CommandManager.Pick(SelectionFilterEnum.kPartEdgeFilter, "Select an edge.")
Dim line As LineSegment = edge.Geometry
Dim startPoint = line.StartPoint
Dim translationVector = oTg.CreateVector(startPoint.X, startPoint.Y, startPoint.Z)
Dim vector1 = oTg.CreateVector(0, 0, 1)
Dim vector2 = line.Direction.AsVector()
Dim matrix As Matrix = oTg.CreateMatrix()
matrix.SetToRotateTo(vector1, vector2)
matrix.SetTranslation(translationVector)
Dim partDoc As PartDocument = ThisDoc.Document
Dim transBRep As TransientBRep = ThisApplication.TransientBRep
Dim transGeom As TransientGeometry = ThisApplication.TransientGeometry
Dim boxMinPoint As Point = transGeom.CreatePoint(0, 0, 0)
Dim boxMaxPoint As Point = transGeom.CreatePoint(10, 0.15, 50)
Dim box As Box = transGeom.CreateBox()
box.Extend(boxMinPoint)
box.Extend(boxMaxPoint)
Dim minBoxSurface As SurfaceBody = ThisApplication.TransientBRep.CreateSolidBlock(box)
Dim cGraphics As ClientGraphics = CreateBox(partDoc, minBoxSurface, matrix)
MsgBox("CHeck the preview")
cGraphics.Delete()
End Sub
Private Function CreateBox(partDoc As Document, surface As Object, matrix As Matrix) As ClientGraphics
Dim cGraphics As ClientGraphics = partDoc.ComponentDefinition.ClientGraphicsCollection.Add("OrientedRangeBox")
Dim surfacesNode As GraphicsNode = cGraphics.AddNode(1)
surfacesNode.Transformation = matrix
Dim surfGraphics As SurfaceGraphics = surfacesNode.AddSurfaceGraphics(surface)
Dim targetAppearance As Asset
Try
targetAppearance = partDoc.Assets.Item("Clear - Blue")
Catch
Dim sourceAppearance As Asset = ThisApplication.AssetLibraries.Item("314DE259-5443-4621-BFBD-1730C6CC9AE9").AppearanceAssets.Item("InvGen-001-1-2") ' "Clear - Blue"
targetAppearance = sourceAppearance.CopyTo(partDoc)
End Try
surfacesNode.Appearance = targetAppearance
ThisApplication.ActiveView.Update()
Return cGraphics
End Function
Jelte de Jong
Blog: hjalte.nl - github.com
