aridass9006
179 Views, 2 Replies
Hidden layer line type as hidden in line properties
i am looking for option or code for my front view hidden lines as hidden layer but in line properties line type also hidden (image attached)
so that if i change the layer in autocad after convert from idw , it ll remain same as hidden line but as named in new layer.
In my company make 3 views as block @ part no & Rev as new layer name(D228851 R0) for our 2d line assembly making , checking & Documentation.
in samecase for center line i found a solution while export to DWG there is a option for change center line's line type as center line. image attached.
i need help for hidden line as hidden even its changed to another layer.
JelteDeJong
in reply to: aridass9006
It seems to me that what you want is the default behaviour in Inventor/Autocad. It should not be necessary to write code for it. And if I export an inventor drawing to DWG I get hidden lines on a hidden line layer.
I guess that I don't understand what you are looking for.
Jelte de Jong
Blog: hjalte.nl - github.com
aridass9006
Hello @JelteDeJong,
that is coming by layer as default. but i need to come only line type as hidden as default whlie convet to dwg.
please find the attached dwg & image.
i hope you ll understand what i am looking for otherwise please ask!.
