A.Acheson
in reply to: dleesuk
Hi @dleesuk
Your error message is your referencing an object without telling the program where to source the object. And further more. The sample I supplied earlier was just looking at note 1 to pick up the style. What you need to do is look at the styles Manager to pick up your standard list of styles( the drop down list in the drawing when you select the note).
Here is a link to the start point of that the drawingdocumentstyles manager.
You would need to follow the objects down to an item within notes collection. Or you can do the opposite and follow it back from general note.style and check the accessed from collection at the bottom, see image.
Syntax DrawingDocument.StylesManager() As DrawingStylesManager
Syntax
DrawingStylesManager.TextStyles() As TextStylesEnumerator
Dim oStlMgr As DrawingStylesManager = oDoc.StylesManager
Dim oTextStyle as TextStyle = oStlMgr.TextStyles.Item(1)
Regards
Alan
