03-09-2024
07:56 PM
- Mute
- Permalink
- Report
03-09-2024
07:56 PM
Hi @dleesuk
One method you could use is to check the text note contents for key words such as NOTES: If found then change the general text style to match the sheet size. This will avoid overwriting the text. Following a style should be easier than trying to overwrite text size directly by code.
SyntaxGeneralNote.TextStyle() As TextStyle
If this solved a problem, please click (accept) as solution.
Or if this helped you, please, click (like)
Regards
Alan
Regards
Alan
