FINET_Laurent
in reply to: dleesuk
HEllo @dleesuk ,
What are your thoughts on this : Instead of a text annotation, why not simply creating a user sketched symbol with prompted entries for each lines ? This way you could have something where you can add/delete lines by filling or not the extra entries. Then, for the scale, you could simply change the size of the sketched symbol on the sheet with a greater / lesser scale factor. This way you wouldn't go around touching the text itself.
Kind regards,
FINET L.
If this post solved your question, please kindly mark it as "Solution"
If this post helped out in any way to solve your question, please drop a "Like"
@LinkedIn     @JohnCockerill
