A.Acheson
in reply to: n_thomasWJZ8L
If you just want to run the rule on the file then when the file is open manually run this external rule. All I have done in this rule is to take the original parameter and use it within the parameter function. This then targets the document to the the current document open when the the rule is run. The update lines at the end update the parameters and the document. The first article linked earlier explains how the various update line works.
If (Parameter("LG") = 17.9375) Then
    Parameter("FTR_POS") = Parameter("DISTANCE_4")
End If
If (Parameter("LG") > 35.9375) Then
    Parameter("FTR_POS") = Parameter("DISTANCE_9")
End If
If ((Parameter("LG")> 17.9375 And (Parameter("LG") < 35.9375 Or (Parameter("LG") = 35.9375) Then
Parameter("FTR_POS")= Parameter("DISTANCE_6") End If
RuleParametersOutput()
iLogicVb.UpdateWhenDone = True.
Regards
Alan
