jeffstoffers
239 Views, 3 Replies
Renaming iLogicForms with iLogic
  I'm wondering if it is possibly to rename an iLogicForm using iLogic? My initial searching makes it look like this might be very tricky or possibly impossible.
I'm using a plugin for furniture design, and I've created a set of components using the plugin that automatically create assemblies with nested assemblies inside controlled by ilogic forms. I have 2 issues.
First if there are multiple copies of the same component I want to see on the form name which copy of the component I'm editing. Second, it seems like you can only have one form with the same name open at a time.
I'm hoping someone can maybe point me in the right direction.
Thank you
