- Mute
- Permalink
- Report
Inventor 2024 PackAndGoLib.PackAndGoComponent CLSID {F2D4F4E5-EEA1-46FF-A83B-A270C92DAE4B} error in 64bit
Hello everyone,
While up until inventor 2023 my code worked just fine (and in fact still does if i use inventor 2023 and not 2024), when I use inventor 2024 then the programm crashes at the line Dim oPacknGoComp As New PackAndGoLib.PackAndGoComponent. The application is compiled for 64bit and the option prefer 32bit is unchecked.
I tried using the dll files from 2023 and from 2024 version but the problem does not go away.
What else could be the issue?
Thank you very much in advance!
- Mute
- Permalink
- Report
Can you try the workaround provided in below post:
Rocky
If this solves the problem please click ACCEPT SOLUTION so other people can find it easily.
Rocky Zhang
Inventor API PD
Manufacturing Solutions
Autodesk, Inc.
- Mute
- Permalink
- Report
Unfortunatelly when trying the steps mensioned on that post I cannot compile the software!
I get the following error message:
Severity Code Description Project File Line Suppression State
Error Could not find file 'Microsoft.Windows.Common-Controls, Version=6.0.0.0, Culture=*, PublicKeyToken=6595b64144ccf1df, ProcessorArchitecture=*, Type=win32'. AppName
- Mute
- Permalink
- Report
Can you share your project(remove all confidential code from it) to us?
Rocky
Rocky Zhang
Inventor API PD
Autodesk, Inc.
- Mute
- Permalink
- Report
Well, that would require a massive refactoring just to send you the project.
What parts of the project do you suspect to be problematic?
Maybe we can focus there.
- Mute
- Permalink
- Report
@a.pournaras Can you just create a new simple project and set the Manifest to check if it works?
Rocky Zhang
Inventor API PD
Autodesk, Inc.
- Mute
- Permalink
- Report
@YuhanZhang I confirm that it works.
I added the two inventor dlls that I need in the refences page and it worked with the new manifest.
