Hi @david_alcalde6P6BN
You can likely make this work by having a local parameter in the assembly file trigger the rule to run. Events for these types of specific objects are rare and are difficult to achieve without going into to addin territory.
Steps to follow
1. Create a local parameter to store your options value.
2. Add this parameter to the rule and monitor it's status. As it is changes in the form this triggers the rule to run.
3. Change your code to activate the positional rep first then the level of detail.
A step I always do before hand is to ensure the exact workflow is achievable manually before attempting to write the steps to automate.
Regards
Alan
