JoAntt
404 Views, 4 Replies
VaultOption
I use this to check out files
invApp.CommandManager.ControlDefinitions.Item("VaultCheckoutTop")
How do i define options with this?
Its the closest i can find that may have something to do with it.
invApp.CommandManager.ControlDefinitions.Item("VaultOption")
I need to set the "Include children" and so on.
bradeneuropeArthur
in reply to: JoAntt
You need to use the Vault API for that kind of things. Only with the Inventor api this will not work.
Arthur Knoors
Autodesk Affiliations:
g.georgiades
in reply to: JoAntt
Find this file here
C:\Users\<USERNAME>\AppData\Roaming\Autodesk\Inventor 2023 Vault Addin\ApplicationPreferences.xml
If Inventor is closed - you can simply modify this file and the changed settings will take effect the next time you open Inventor.
If Inventor is open - read the ID and Name from the file and you can use this iLogic snippet to set the values.
Imports Autodesk.DataManagement.Client.Framework.Forms
AddReference "Autodesk.DataManagement.Client.Framework.Forms.dll"
'Library.ApplicationPreferences.Load() 'Load modified settings if file edited outside of Inventor process.
Library.ApplicationPreferences.Set("CheckInDialogOptions", "IncludeChildren", True) 'Directly sets the setting right from the iLogic Rule.
See this post to edit vault prompts. Those are handled differently.
https://forums.autodesk.com/t5/inventor-programming-ilogic/is-there-a-why-to-change-promt-or-not-bei...
JoAntt
in reply to: g.georgiades
Thank you!
Skadborg.NTI
Oops - wrong thread
