- Mute
- Permalink
- Report
hello @A.Acheson ,
here is the derived script i have been using so far. now about the work flow, I have thought about an approach which seems pretty straight forward but want to test the feasibility (coding wise). So I have and excel in the same directory as the current Idw file for example. now there is only one sheet in that workbook and as per the image shown below, I have three column, now from the ilogic, I want to open the excel and start a "for loop" from 2nd row till the row 2500 for example. Now looping through each row, I want to change the "DUMMY 1" Ipart member to the column A cell value, similarly I want to do the same for the other two views and their Ipart. So every time we jump to a new row, all the three views is gonna get updated to the member name in row. Can we achieve this using Ilogic? Thanks in Advance!
Sub Main Dim oDrawing As DrawingDocument = ThisApplication.ActiveDocument Dim oPath As String = "C:\IMAGINE" 'Folder to save the drawings Dim oFactory As iPartFactory For Each oView As DrawingView In oDrawing.ActiveSheet.DrawingViews Dim oDoc As Document = oView.ReferencedDocumentDescriptor.ReferencedDocument oFactory = oDoc.ComponentDefinition.ipartMember.ParentFactory Exit For Next Dim memberName As String = InputBox("Enter the Membername you wish to Start the Loop", "iLogic", "CBCAL0820PL01") If oFactory Is Nothing = False Then For Each oRow As iPartTableRow In oFactory.TableRows If Not oRow.MemberName = memberName AndAlso Not memberName Is Nothing Then Continue For memberName = Nothing For Each oView In oDrawing.ActiveSheet.DrawingViews If oView.ActiveMemberName <> oRow.MemberName Then oView.ActiveMemberName = oRow.MemberName oDrawing.Update ' Get the DXF translator Add-In. Dim DXFAddIn As TranslatorAddIn DXFAddIn = ThisApplication.ApplicationAddIns.ItemById("{C24E3AC4-122E-11D5-8E91-0010B541CD80}") 'Set a reference to the active document (the document to be published). Dim oDocument As Document oDocument = ThisApplication.ActiveDocument Dim oContext As TranslationContext oContext = ThisApplication.TransientObjects.CreateTranslationContext oContext.Type = IOMechanismEnum.kFileBrowseIOMechanism ' Create a NameValueMap object Dim oOptions As NameValueMap oOptions = ThisApplication.TransientObjects.CreateNameValueMap ' Create a DataMedium object Dim oDataMedium As DataMedium oDataMedium = ThisApplication.TransientObjects.CreateDataMedium ' Check whether the translator has 'SaveCopyAs' options If DXFAddIn.HasSaveCopyAsOptions(oDocument, oContext, oOptions) Then Dim strIniFile As String strIniFile = "C:\temp\dxfout.ini" ' Create the name-value that specifies the ini file to use. oOptions.Value("Export_Acad_IniFile") = strIniFile End If 'Set the destination file name Dim dxfFileName As String = oPath & "\DXF\" & oRow.MemberName & ".dxf" oDataMedium.FileName = dxfFileName iLogicVb.RunRule("FIXED SCALE") iLogicVb.RunRule("POSITION") 'Publish document. oDrawing.Update DXFAddIn.SaveCopyAs(oDocument, oContext, oOptions, oDataMedium) Do While oView.IsUpdateComplete = False Call ThisApplication.UserInterfaceManager.DoEvents Loop Next 'oDrawing.SaveAs(oPath & "\" & oRow.MemberName & ".idw", True) 'oDrawing.SaveAs(oPath & "\PDF\" & oRow.MemberName & ".pdf", True) Next End If End Sub
