02-15-2024
03:29 PM
- Mute
- Permalink
- Report
02-15-2024
03:29 PM
Here is an iLogic friendly version for testing:
AddReference "System.Xml"
AddReference "System.Xml.Linq"
Imports System.Xml
Imports System.Xml.Linq
Sub Main
Dim dDoc As DrawingDocument = TryCast(ThisApplication.ActiveDocument, DrawingDocument)
If IsNothing(dDoc) Then Logger.Debug("Not Run In Drawing Document") : Exit Sub
Dim HatchMap As NameValueMap = BuildHatchMap(dDoc.StylesManager.ActiveStandardStyle.Name)
If HatchMap Is Nothing Then Exit Sub
MessageBox.Show(HatchMap.Count, "Materials Mapped to Hatches")
End Sub
Private Function BuildHatchMap(StyleName As String) As NameValueMap
Dim OutputMap As NameValueMap = ThisApplication.TransientObjects.CreateNameValueMap()
Dim DesignDateFolder As String = ThisApplication.DesignProjectManager.ActiveDesignProject.DesignDataPath
Dim StandardXMLFullFileName As String = DesignDateFolder & "standard.xml"
Dim GenericStyleHeading As String = "Style"
Dim HatchMapHeading As String = "HatchMaterialMap"
Dim MaterialAttribute As String = "Material"
Dim PatternHeading As String = "PatternLine"
Dim StandardXMLdoc As XDocument = XDocument.Load(StandardXMLFullFileName)
Dim styleElement As XElement
For Each s As XElement In StandardXMLdoc.Descendants(GenericStyleHeading)
If s.Value.Contains(StyleName) Then styleElement = s : Exit For
Next
If styleElement.Value Is String.Empty Then Return Nothing
Dim HatchMapXElement As XElement = styleElement.Descendants(HatchMapHeading)(0)
If HatchMapXElement.Value Is String.Empty Then Return Nothing
'Now We need to parse this for Materials
For Each s As XElement In HatchMapXElement.Elements()
Dim MaterialName As String = s.Attribute(MaterialAttribute).Value
Dim PatternLine0 As String = s.Descendants(PatternHeading)(0).Value.Split(",")(0)
PatternLine0 = Right(PatternLine0, PatternLine0.Length - 1)
OutputMap.Add(MaterialName, PatternLine0)
Next
Return OutputMap
End Function
