J-Camper
in reply to: WCrihfield
@WCrihfield,
I was able to put this together:
Private Function BuildHatchMap(StyleName As String) As NameValueMap
	Dim OutputMap As NameValueMap = g_inventorApplication.TransientObjects.CreateNameValueMap()
	Dim DesignDateFolder As String = g_inventorApplication.DesignProjectManager.ActiveDesignProject.DesignDataPath
	Dim StandardXMLFullFileName As String = DesignDateFolder & "standard.xml"
	Dim GenericStyleHeading As String = "Style"
	Dim HatchMapHeading As String = "HatchMaterialMap"
	Dim MaterialAttribute As String = "Material"
	Dim PatternHeading As String = "PatternLine"
	Dim StandardXMLdoc As XDocument = XDocument.Load(StandardXMLFullFileName)
	Dim styleElement As XElement
	For Each s As XElement In StandardXMLdoc.Descendants(GenericStyleHeading)
		If s.Value.Contains(StyleName) Then styleElement = s : Exit For
	Next
	If styleElement.Value Is String.Empty Then Return Nothing
	Dim HatchMapXElement As XElement = styleElement.Descendants(HatchMapHeading)(0)
	If HatchMapXElement.Value Is String.Empty Then Return Nothing
	'Now We need to parse this for Materials
	For Each s As XElement In HatchMapXElement.Elements()
		Dim MaterialName As String = s.Attribute(MaterialAttribute).Value
		Dim PatternLine0 As String = s.Descendants(PatternHeading)(0).Value.Split(",")(0)
		PatternLine0 = Right(PatternLine0, PatternLine0.Length - 1)
		OutputMap.Add(MaterialName, PatternLine0)
	Next
	Return OutputMap
End Function
It builds a namevaluemap for the StyleStandard name provided.  I was feeding from Main:
dDoc.StylesManager.ActiveStandardStyle.Name
I'm wondering if anyone has a more elegant solution.
