nuclair
229 Views, 2 Replies
Change part number to filename for all parts and subs in a assembly
Hi All!
For a i'm going to migrate a lot of files from solidworks to inventor and later push them in to the Autodesk Vault.
They did not use a lot of logic in the partnumbers so i'm trying to implement a new numbering logic while migrating to inventor.
Therefore i'm changing the filenames in the windows filebrowser but i'm experiencing that the part number is not the same as the filenumber when I change the name in the filebrowser.
1. Is there a better way to do the above?
2. Is there a piece of code to change the Part number in to the filename for all parts and subs in a assembly?
Thanks in advance!
