david_lowndes
231 Views, 3 Replies
Rule to Open Drawing of every part in Assembly
Hi.
I have written rules to open drawings based on the BOM before, but now I am using vault I am trying to use
ThisApplication.CommandManager.ControlDefinitions.Item("VaultOpenDesignDocFromVault").Execute
I know to get this to work I need to select an Occurrence first, so I am using
ThisApplication.CommandManager.DoSelect(oOcc)
But my rule just keeps opening the same drawing over and over. Do I need to clear the selection somehow?
Here is the code in question:
    For i =1 To oBOMRows.Count
        BOMItem = oBOMView.BOMRows.Item(i)
        oCompDef = BOMItem.ComponentDefinitions.Item(1)
        'If oCompDef.BOMStructure <> 51972 Then
        If oCompDef.BOMStructure <> 51973 Then
            PartNum = oCompDef.Document.PropertySets.Item("Design Tracking Properties").Item("Part Number").Value
            VenNum = oCompDef.Document.PropertySets.Item("Design Tracking Properties").Item("Vendor").Value
            DesNum = oCompDef.Document.PropertySets.Item("Design Tracking Properties").Item("Description").Value
            'PartNum = oCompDef.Document.PropertySets.Item(4).Item(2).Value
            Dim LongName As String = PartNum & " " & DesNum
			Try
				MsgBox(PartNum)
				oOcc = Component.InventorComponent(PartNum & ":1")
				'MsgBox("Got Occurence of " & PartNum)
				CurrentDocName = oCompDef.Document.FullFileName
			Catch
				Msgbox("Failed to get" & PartNum)
            End Try
        Else
            'do nothing
        End If
		Try
			DrawDoc = ThisApplication.ActiveDocument
			DrawName = DrawDoc.FullFileName
			DrawDoc.Close
		Catch
		End Try
    Next
 Thanks to anyone who can help
