wmgshurik
239 Views, 2 Replies
Model leader note annotation point collection
Hello friends!
I don't undarstand, why this code doesnt work.
I catch Argument Exception in .ModelLeaderNotes.CreateDefinition method.
If "ObjectCollection objects" has one point - it works, if it has more points - not works..
All points lie on the same plane. Documentation says thet Inventor project this points on the plane.
public void CreateTechNumberAnnotation(DependencyObjects DO, ComponentOccurrence occ)
    AssemblyComponentDefinition topCompDef = occ.Parent;
    WorkPlane workPlane;
    WorkPoints workPoints;
    if (occ.ReferencedFileDescriptor.FullFileName.EndsWith("iam"))
        workPoints = ( (AssemblyDocument)occ.Definition.Document ).ComponentDefinition.WorkPoints;
    else
        workPoints = ( (PartDocument)occ.Definition.Document ).ComponentDefinition.WorkPoints;
    //occ original point
    occ.CreateGeometryProxy(workPoints[1], out object temp);
    var workPointProxy = (WorkPointProxy)temp;
    GeometryIntent intentRoot = topCompDef.CreateGeometryIntent(workPointProxy);
   //occ last point
    Point endPoint = DO.TG.CreatePoint(workPoints[1].Point.X + 10, workPoints[1].Point.Y + 10, workPoints[1].Point.Z);
    workPoints.AddFixed(endPoint);
    endPoint = DO.TG.CreatePoint(workPoints[workPoints.Count].Point.X, workPoints[workPoints.Count].Point.Z,                workPoints[workPoints.Count].Point.Z);
    occ.Definition.Document.Update2();
    occ.CreateGeometryProxy(workPoints[workPoints.Count - 1], out temp);
    var workPointProxyText = (WorkPointProxy)temp;
    GeometryIntent intentText = topCompDef.CreateGeometryIntent(workPointProxyText);
    occ.CreateGeometryProxy(workPoints[workPoints.Count], out temp);
    var workPointProxyTextEnd = (WorkPointProxy)temp;
    GeometryIntent intentTextEnd = topCompDef.CreateGeometryIntent(workPointProxyTextEnd);
    workPlane = topCompDef.WorkPlanes[3];
    AnnotationPlaneDefinition annotationPlaneDef =         topCompDef.ModelAnnotations.CreateAnnotationPlaneDefinitionUsingPlane(workPlane);
    ObjectCollection objects = DO.InvApp.TransientObjects.CreateObjectCollection();
    objects.Add(intentTextEnd);
    objects.Add(intentText);
    objects.Add(intentRoot);
    ModelLeaderNoteDefinition leaderDef = topCompDef.ModelAnnotations.ModelLeaderNotes.CreateDefinition(objects, "Text", annotationPlaneDef);
    topCompDef.ModelAnnotations.ModelLeaderNotes.Add(leaderDef);
