02-01-2024
07:04 AM
- Mute
- Permalink
- Report
02-01-2024
07:04 AM
export all open files to pdf with revision level
I am still somewhat new to iLogic, I have this code that I have gotten from the forums and modified to export all open drawings to pdf in a single folder. It works great with only one problem. I include a custom iproperty of "REV LEVEL" in the file name. The issue is it takes the revision level of the first drawing and uses it for all the other drawings. How is that value reset or changed between each loop thru the code?
Sub Main() Dim myDate As String = Now().ToString("yyyy-MM-dd HHmmss") myDate = myDate.Replace(":","") ' & " - " & TypeString userChoice = InputRadioBox("Defined the scope", "This Document", "All Open Documents", True, Title := "Defined the scope") UserSelectedActionList = New String(){"DXF & PDF", "PDF Only", "DXF Only"} UserSelectedAction = InputListBox("What action must be performed with selected views?", _ UserSelectedActionList, UserSelectedActionList(0), Title := "Action to Perform", ListName := "Options") Select UserSelectedAction Case "DXF & PDF": UserSelectedAction = 3 Case "PDF Only": UserSelectedAction = 1 Case "DXF Only": UserSelectedAction = 2 End Select If userChoice Then Call MakePDFFromDoc(ThisApplication.ActiveDocument, myDate, UserSelectedAction) Else For Each oDoc In ThisApplication.Documents If oDoc.DocumentType = kDrawingDocumentObject Try If Len(oDoc.File.FullFileName)>0 Then Call MakePDFFromDoc(oDoc, myDate, UserSelectedAction) End If Catch End Try End If Next End If End Sub Sub MakePDFFromDoc(ByRef oDocument As Document, DateString As String, UserSelectedAction As Integer) ' oPath = oDocument.Path ' oFileName = oDocument.FileName(False) 'without extension 'oDocument = ThisApplication.ActiveDocument oPDFAddIn = ThisApplication.ApplicationAddIns.ItemById _ ("{0AC6FD96-2F4D-42CE-8BE0-8AEA580399E4}") oContext = ThisApplication.TransientObjects.CreateTranslationContext oContext.Type = IOMechanismEnum.kFileBrowseIOMechanism oOptions = ThisApplication.TransientObjects.CreateNameValueMap oDataMedium = ThisApplication.TransientObjects.CreateDataMedium oFullFileName = oDocument.File.FullFileName oPath = "C:\Users\eric.smyth\OneDrive - CPM Holdings Inc\Desktop\pdf folder" 'oPath = Left(oFullFileName, InStrRev(oFullFileName, "\")-1) oFileName = Right(oFullFileName, Len(oFullFileName)-InStrRev(oFullFileName, "\")) oFilePart = Left(oFileName, InStrRev(oFileName, ".")-1) 'oRevNum = oDocument.iProperties.Value("Project", "Revision Number") oRevNum1= iProperties.Value("Custom", "REV LEVEL") 'oDocument = ThisApplication.ActiveDocument ' If oPDFAddIn.HasSaveCopyAsOptions(oDataMedium, oContext, oOptions) Then oOptions.Value("All_Color_AS_Black") = 0 oOptions.Value("Remove_Line_Weights") = 0 oOptions.Value("Vector_Resolution") = 400 oOptions.Value("Sheet_Range") = Inventor.PrintRangeEnum.kPrintAllSheets 'oOptions.Value("Custom_Begin_Sheet") = 2 'oOptions.Value("Custom_End_Sheet") = 4 ' End If 'get PDF target folder path 'oFolder = Left(oPath, InStrRev(oPath, "\")) & "PDF" oFolder = oPath 'oFolder = oPath & "\iLogic PDF's (" & DateString & ")" 'Check for the PDF folder and create it if it does not exist If Not System.IO.Directory.Exists(oFolder) Then System.IO.Directory.CreateDirectory(oFolder) End If 'Set the PDF target file name 'DataMedium.FileName = "\" & oFileName & "_r" & oRevNum1 & ".pdf" oDataMedium.FileName = oFolder & "\" & oFilePart & "_r" & oRevNum1 & ".pdf" 'PDFName = PDFPath & "\" & oFileName & "_r" & oRevNum1 & ".pdf" 'Publish document If (UserSelectedAction = 1) Or (UserSelectedAction = 3) Then oPDFAddIn.SaveCopyAs(oDocument, oContext, oOptions, oDataMedium)'For PDF's End If If (UserSelectedAction = 2) Or (UserSelectedAction = 3) Then oDocument.SaveAs(oFolder & "\" & oFilePart & ".dxf", True) 'For DXF's End If 'oDocument.SaveAs(oFolder & "\" & ThisDoc.ChangeExtension(".dxf"), True) 'For DXF's '------end of iLogic------- End Sub
