- Mute
- Permalink
- Report
export all open files to pdf with revision level
I am still somewhat new to iLogic, I have this code that I have gotten from the forums and modified to export all open drawings to pdf in a single folder. It works great with only one problem. I include a custom iproperty of "REV LEVEL" in the file name. The issue is it takes the revision level of the first drawing and uses it for all the other drawings. How is that value reset or changed between each loop thru the code?
Sub Main() Dim myDate As String = Now().ToString("yyyy-MM-dd HHmmss") myDate = myDate.Replace(":","") ' & " - " & TypeString userChoice = InputRadioBox("Defined the scope", "This Document", "All Open Documents", True, Title := "Defined the scope") UserSelectedActionList = New String(){"DXF & PDF", "PDF Only", "DXF Only"} UserSelectedAction = InputListBox("What action must be performed with selected views?", _ UserSelectedActionList, UserSelectedActionList(0), Title := "Action to Perform", ListName := "Options") Select UserSelectedAction Case "DXF & PDF": UserSelectedAction = 3 Case "PDF Only": UserSelectedAction = 1 Case "DXF Only": UserSelectedAction = 2 End Select If userChoice Then Call MakePDFFromDoc(ThisApplication.ActiveDocument, myDate, UserSelectedAction) Else For Each oDoc In ThisApplication.Documents If oDoc.DocumentType = kDrawingDocumentObject Try If Len(oDoc.File.FullFileName)>0 Then Call MakePDFFromDoc(oDoc, myDate, UserSelectedAction) End If Catch End Try End If Next End If End Sub Sub MakePDFFromDoc(ByRef oDocument As Document, DateString As String, UserSelectedAction As Integer) ' oPath = oDocument.Path ' oFileName = oDocument.FileName(False) 'without extension 'oDocument = ThisApplication.ActiveDocument oPDFAddIn = ThisApplication.ApplicationAddIns.ItemById _ ("{0AC6FD96-2F4D-42CE-8BE0-8AEA580399E4}") oContext = ThisApplication.TransientObjects.CreateTranslationContext oContext.Type = IOMechanismEnum.kFileBrowseIOMechanism oOptions = ThisApplication.TransientObjects.CreateNameValueMap oDataMedium = ThisApplication.TransientObjects.CreateDataMedium oFullFileName = oDocument.File.FullFileName oPath = "C:\Users\eric.smyth\OneDrive - CPM Holdings Inc\Desktop\pdf folder" 'oPath = Left(oFullFileName, InStrRev(oFullFileName, "\")-1) oFileName = Right(oFullFileName, Len(oFullFileName)-InStrRev(oFullFileName, "\")) oFilePart = Left(oFileName, InStrRev(oFileName, ".")-1) 'oRevNum = oDocument.iProperties.Value("Project", "Revision Number") oRevNum1= iProperties.Value("Custom", "REV LEVEL") 'oDocument = ThisApplication.ActiveDocument ' If oPDFAddIn.HasSaveCopyAsOptions(oDataMedium, oContext, oOptions) Then oOptions.Value("All_Color_AS_Black") = 0 oOptions.Value("Remove_Line_Weights") = 0 oOptions.Value("Vector_Resolution") = 400 oOptions.Value("Sheet_Range") = Inventor.PrintRangeEnum.kPrintAllSheets 'oOptions.Value("Custom_Begin_Sheet") = 2 'oOptions.Value("Custom_End_Sheet") = 4 ' End If 'get PDF target folder path 'oFolder = Left(oPath, InStrRev(oPath, "\")) & "PDF" oFolder = oPath 'oFolder = oPath & "\iLogic PDF's (" & DateString & ")" 'Check for the PDF folder and create it if it does not exist If Not System.IO.Directory.Exists(oFolder) Then System.IO.Directory.CreateDirectory(oFolder) End If 'Set the PDF target file name 'DataMedium.FileName = "\" & oFileName & "_r" & oRevNum1 & ".pdf" oDataMedium.FileName = oFolder & "\" & oFilePart & "_r" & oRevNum1 & ".pdf" 'PDFName = PDFPath & "\" & oFileName & "_r" & oRevNum1 & ".pdf" 'Publish document If (UserSelectedAction = 1) Or (UserSelectedAction = 3) Then oPDFAddIn.SaveCopyAs(oDocument, oContext, oOptions, oDataMedium)'For PDF's End If If (UserSelectedAction = 2) Or (UserSelectedAction = 3) Then oDocument.SaveAs(oFolder & "\" & oFilePart & ".dxf", True) 'For DXF's End If 'oDocument.SaveAs(oFolder & "\" & ThisDoc.ChangeExtension(".dxf"), True) 'For DXF's '------end of iLogic------- End Sub
- Mute
- Permalink
- Report
Your sub "MakePDFFromDoc()" is being called with "ThisApplication.ActiveDocument". Therefore, it is always only going to make the PDF from the active document on screen.
You instead need to loop through each of the open document(s), calling "MakePDFFromDoc" on each document.
- Mute
- Permalink
- Report
isn't Sub Main() looping thru all "ThisApplication.Documents" and then calling "MakePDFFromDoc" on each document? It is saving all the drawings as pdfs, its not getting the correct "rev level" for each.
- Mute
- Permalink
- Report
Ah, sorry about that, you are correct. I misread the code.
I generally avoid iLogic, and go straight to the Inventor API. My guess is the iLogic: "iProperties" is grabbing info for the active document.
I see you might have been trying 'Document.iProperties" in the commented code, which would have errored because that doesn't exist. Instead, try the Inventor API: "Document.PropertySets"
https://help.autodesk.com/view/INVNTOR/2022/ENU/?guid=Document_FilePropertySets
Example here:
https://help.autodesk.com/view/INVNTOR/2022/ENU/?guid=iPropertyGetValue_Sample
