01-30-2024
10:16 AM
- Mute
- Permalink
- Report
01-30-2024
10:16 AM
Hey Chris,
Did you ever figure out a solution to this? I'm going through the EXACT same process as you for auto-generating balloons. I've already placed Named Workpoints, pulled them in, generated proper geometry intent coordinates....only for it to fail right when I go to generate the balloons. I've correctly established that it has something to do with Workpoints not maintaining any sort of association with the models that they are pulled from, but besides going back to that suggested code that someone posted earlier in this thread, I wanted to know if you found any sort of work around? I've found that that suggested code doesn't always work (hence why I changed to this method).
Any suggestions would be awesome.
Thanks!
