A.Acheson
in reply to: dparmarF6BDE
Hi @dparmarF6BDE
What your suggesting is more than likely possible. There is a lot of work to go into R&D your workflow so I am assuming your post is more for advice. I would suggest to break it down into bite size lists following closely your manual workflow. Once you have a list operations starting looking for suitable blocks of code to automate those tasks. I would suggest using all external rules. If you have been at this a while you likely have something you can reuse.
I am not certain what type of automation you want on the drawing but here is one workflow you undertook awhile back
If you want help with any specific aspect please post the code your using along with a description of what you want to do next and what the code is doing currently.
Happy Automating....
Regards
Alan
