- Mute
- Permalink
- Report
Automated Drawings for parts, views update and export as pdf
Hello All,
I am trying to create automated finished good drawing in bulk using Ilogic. I am using inventor 2024. The goal here is to update a part which is an ipart factory part and based on the new updated part, all the other parts inn the drawing i want to update and after the update, I want to export that drawing as a pdf file and move on to the next part.
As per the image, lets assume that the part "DUMMY_1" has a part name as it is a master part of the ipart factory and the current member name is "10-28", based on the 10-28 i want to update the part "DUMMY_2" to update to a member where it matches with my requirements and as same as the previous situation, I want to update the part"DUMMY_3" based on the certain characters in the Part name of the "DUMMY_1" part. after updating the members in all three views. We can save the file at given location as a PDF. Things to keep in mind, all three are an ipart factory parts, I have the parts made as a child parts for all three of them as well, whatever works and easy on the system so it wont crash. Thanks in advance! Happy manufacturing!
@A.Acheson
- Mute
- Permalink
- Report
What your suggesting is more than likely possible. There is a lot of work to go into R&D your workflow so I am assuming your post is more for advice. I would suggest to break it down into bite size lists following closely your manual workflow. Once you have a list operations starting looking for suitable blocks of code to automate those tasks. I would suggest using all external rules. If you have been at this a while you likely have something you can reuse.
I am not certain what type of automation you want on the drawing but here is one workflow you undertook awhile back.
If you want help with any specific aspect please post the code your using along with a description of what you want to do next and what the code is doing currently.
Happy Automating....
Or if this helped you, please, click (like)
Regards
Alan
- Mute
- Permalink
- Report
hello @A.Acheson ,
here is the derived script i have been using so far. now about the work flow, I have thought about an approach which seems pretty straight forward but want to test the feasibility (coding wise). So I have and excel in the same directory as the current Idw file for example. now there is only one sheet in that workbook and as per the image shown below, I have three column, now from the ilogic, I want to open the excel and start a "for loop" from 2nd row till the row 2500 for example. Now looping through each row, I want to change the "DUMMY 1" Ipart member to the column A cell value, similarly I want to do the same for the other two views and their Ipart. So every time we jump to a new row, all the three views is gonna get updated to the member name in row. Can we achieve this using Ilogic? Thanks in Advance!
Sub Main Dim oDrawing As DrawingDocument = ThisApplication.ActiveDocument Dim oPath As String = "C:\IMAGINE" 'Folder to save the drawings Dim oFactory As iPartFactory For Each oView As DrawingView In oDrawing.ActiveSheet.DrawingViews Dim oDoc As Document = oView.ReferencedDocumentDescriptor.ReferencedDocument oFactory = oDoc.ComponentDefinition.ipartMember.ParentFactory Exit For Next Dim memberName As String = InputBox("Enter the Membername you wish to Start the Loop", "iLogic", "CBCAL0820PL01") If oFactory Is Nothing = False Then For Each oRow As iPartTableRow In oFactory.TableRows If Not oRow.MemberName = memberName AndAlso Not memberName Is Nothing Then Continue For memberName = Nothing For Each oView In oDrawing.ActiveSheet.DrawingViews If oView.ActiveMemberName <> oRow.MemberName Then oView.ActiveMemberName = oRow.MemberName oDrawing.Update ' Get the DXF translator Add-In. Dim DXFAddIn As TranslatorAddIn DXFAddIn = ThisApplication.ApplicationAddIns.ItemById("{C24E3AC4-122E-11D5-8E91-0010B541CD80}") 'Set a reference to the active document (the document to be published). Dim oDocument As Document oDocument = ThisApplication.ActiveDocument Dim oContext As TranslationContext oContext = ThisApplication.TransientObjects.CreateTranslationContext oContext.Type = IOMechanismEnum.kFileBrowseIOMechanism ' Create a NameValueMap object Dim oOptions As NameValueMap oOptions = ThisApplication.TransientObjects.CreateNameValueMap ' Create a DataMedium object Dim oDataMedium As DataMedium oDataMedium = ThisApplication.TransientObjects.CreateDataMedium ' Check whether the translator has 'SaveCopyAs' options If DXFAddIn.HasSaveCopyAsOptions(oDocument, oContext, oOptions) Then Dim strIniFile As String strIniFile = "C:\temp\dxfout.ini" ' Create the name-value that specifies the ini file to use. oOptions.Value("Export_Acad_IniFile") = strIniFile End If 'Set the destination file name Dim dxfFileName As String = oPath & "\DXF\" & oRow.MemberName & ".dxf" oDataMedium.FileName = dxfFileName iLogicVb.RunRule("FIXED SCALE") iLogicVb.RunRule("POSITION") 'Publish document. oDrawing.Update DXFAddIn.SaveCopyAs(oDocument, oContext, oOptions, oDataMedium) Do While oView.IsUpdateComplete = False Call ThisApplication.UserInterfaceManager.DoEvents Loop Next 'oDrawing.SaveAs(oPath & "\" & oRow.MemberName & ".idw", True) 'oDrawing.SaveAs(oPath & "\PDF\" & oRow.MemberName & ".pdf", True) Next End If End Sub
- Mute
- Permalink
- Report
I wouldn't see an issue doing that. Your just looking up the excel value and changing each member on each view to match. Have you looked at go excel examples on this forum? First thing you needed to do is to read the excel sheet and bring back the correct value.
Regards
Alan
- Mute
- Permalink
- Report
Hello @A.Acheson ,
in this script, how would we identify more than one view in our script if they are in the drawing. I have three views and their names are view1, view2 and view3. I want to update these all view at every stage of the loop since they all have different ipart factory parts. I got the script for excel and here it is, I am still trying to construct the code, so it will follow this workflow.
1. go to row 1 in excel
2. update the view1 ipart partmember to Cell A1
3. update the view2 ipart partmember to Cell B1
4. update the view3 ipart partmember to Cell C1
5. update the drawing and arrange the dimensions on those views.
6. save it as a pdf and the name of the file is in the excel so cell D1 value has to match with the file name for that loop.
7. jump to the next row
here i want to assign the cell values to the different views and their active partmember, if you can help me out a bit here! I would really appreciate this. thanks in advance. The first script is the one that i modified a bit and the second script is the one that you gave me as a solution of my questions before.
owbook = "C:" owSheet = "MASTER" GoExcel.Open(owbook,owSheet) 'start row to use Dim oStartRow As Integer oStartRow = 1 'number of rows to use Dim oRowlastcount As Long oRowlastcount = 25 '--------------------------------------------------------------------------------------------------------------------------------' Dim oCrossSecdoc As DrawingDocument = ThisApplication.ActiveDocument oCrossSecdoc = ThisApplication.ActiveDocument Dim oFactory As iPartFactory Dim oView1Member As String Dim oView2Member As String Dim oView3Member As String '--------------------------------------------------------------------------------------------------------------------------------' Dim i As Integer For i = oStartRow To oRowlastcount Dim strx As String, stry As String strx = GoExcel.CellValue(owbook,owSheet, "A" & i) stry = GoExcel.CellValue(owbook,owSheet, "B" & i) Next
Sub Main Dim oDrawing As DrawingDocument = ThisApplication.ActiveDocument Dim oPath As String = "C:\" 'Folder to save the drawings Dim oFactory As iPartFactory For Each oView As DrawingView In oDrawing.ActiveSheet.DrawingViews Dim oDoc As Document = oView.ReferencedDocumentDescriptor.ReferencedDocument oFactory = oDoc.ComponentDefinition.ipartMember.ParentFactory Exit For Next Dim memberName As String = InputBox("Enter the Membername you wish to Start the Loop", "iLogic", "abcd") If oFactory Is Nothing = False Then For Each oRow As iPartTableRow In oFactory.TableRows If Not oRow.MemberName = memberName AndAlso Not memberName Is Nothing Then Continue For memberName = Nothing For Each oView In oDrawing.ActiveSheet.DrawingViews If oView.ActiveMemberName <> oRow.MemberName Then oView.ActiveMemberName = oRow.MemberName oDrawing.Update ' Get the DXF translator Add-In. Dim DXFAddIn As TranslatorAddIn DXFAddIn = ThisApplication.ApplicationAddIns.ItemById("{C24E3AC4-122E-11D5-8E91-0010B541CD80}") 'Set a reference to the active document (the document to be published). Dim oDocument As Document oDocument = ThisApplication.ActiveDocument Dim oContext As TranslationContext oContext = ThisApplication.TransientObjects.CreateTranslationContext oContext.Type = IOMechanismEnum.kFileBrowseIOMechanism ' Create a NameValueMap object Dim oOptions As NameValueMap oOptions = ThisApplication.TransientObjects.CreateNameValueMap ' Create a DataMedium object Dim oDataMedium As DataMedium oDataMedium = ThisApplication.TransientObjects.CreateDataMedium ' Check whether the translator has 'SaveCopyAs' options If DXFAddIn.HasSaveCopyAsOptions(oDocument, oContext, oOptions) Then Dim strIniFile As String strIniFile = "C:\temp\dxfout.ini" ' Create the name-value that specifies the ini file to use. oOptions.Value("Export_Acad_IniFile") = strIniFile End If 'Set the destination file name Dim dxfFileName As String = oPath & "\DXF\" & oRow.MemberName & ".dxf" oDataMedium.FileName = dxfFileName iLogicVb.RunRule("FIXED SCALE") iLogicVb.RunRule("POSITION") 'Publish document. oDrawing.Update DXFAddIn.SaveCopyAs(oDocument, oContext, oOptions, oDataMedium) Do While oView.IsUpdateComplete = False Call ThisApplication.UserInterfaceManager.DoEvents Loop Next 'oDrawing.SaveAs(oPath & "\" & oRow.MemberName & ".idw", True) 'oDrawing.SaveAs(oPath & "\PDF\" & oRow.MemberName & ".pdf", True) Next End If End Sub
- Mute
- Permalink
- Report
t to separate the views you would do so in the For Loop of Drawing Views.
You can either call a sub routine and offer the view as an argument or you can filter the view object within the loop but in this case all of the routine needs to be within this loop. A sub routine might be a cleaner approach.
See example here, it isn't finished but you should get the structure.
Sub Main
If oView.Name = "view1" Then
'update the view1 ipart partmember to Cell A1, pass the excelvalue for partmember into the sub routine as argument
partMember = 1
ProcessView(drawView,partMember)
ElseIf View.Name = "view2" Then
'update the view1 ipart partmember to Cell B1, pass the excelvalue for partmember into the sub routine as argument
partMember = 2
ElseIf View.Name = "view3" Then
'update the view1 ipart partmember to Cell C1, pass the excelvalue for partmember into the sub routine as argument
partMember = 3
End IF
Next
End Sub
Sub ProcessView(drawView As DrawingView,partMember As String)
'Do something with the view object
MessageBox.Show(partMember, "partMember")
MessageBox.Show(drawView.Name,"Drawing View Name")
End Sub
Regards
Alan
- Mute
- Permalink
- Report
Hello @A.Acheson ,
I am trying an approach, derived from the previous script and cant make it working. instead of trying to loop through each view, is it possible to define separate view variable in advance from the labels of the view, so as soon as we jump on the next row, we can change the partmember by excel values. If you think it is not a right approach, please provide the previous code with at least one view example, as I am struggling with the structure. the biggest challenge is to define the view then define the partfactroy for the member that is in that view. thanks again!
Sub Main Dim oCrossSecdoc As DrawingDocument = ThisApplication.ActiveDocument Dim oPathpdf As String = "C:\" 'Folder to save the drawings Dim oFactory As iPartFactory owbook = "C:" owSheet = "MASTER" GoExcel.Open(owbook,owSheet) Dim oView1Member As String Dim oView2Member As String Dim oView3Member As String Dim currentfilename As String Dim oView1 As DrawingView oView1 = oCrossSecdoc.ActiveSheet.DrawingViews(1) Dim oView2 As DrawingView oView1 = oCrossSecdoc.ActiveSheet.DrawingViews(2) Dim oView3 As DrawingView oView1 = oCrossSecdoc.ActiveSheet.DrawingViews(3) Dim oPartDoc1 As PartDocument oPartDoc1 = oView1.ReferencedDocumentDescriptor.ReferencedDocument ' Dim oPartDoc2 As PartDocument ' oPartDoc2 = oView2.ReferencedDocumentDescriptor.ReferencedDocument ' Dim oPartDoc3 As PartDocument ' oPartDoc3 = oView3.ReferencedDocumentDescriptor.ReferencedDocument Dim oDef1 As PartComponentDefinition oDef1 = oPartDoc1.ComponentDefinition Dim oDef2 As PartComponentDefinition ' oDef2 = oPartDoc2.ComponentDefinition Dim oDef3 As PartComponentDefinition ' oDef3 = oPartDoc3.ComponentDefinition Dim iPart1 As iPartFactory Dim iPart2 As iPartFactory Dim iPart3 As iPartFactory Dim oRow1 As iPartTableRow Dim oRow2 As iPartTableRow Dim oRow3 As iPartTableRow iPart1 = oDef1.iPartMember.ParentFactory ' iPart2 = oDef2.iPartMember.ParentFactory ' iPart3 = oDef3.iPartMember.ParentFactory Dim i As Integer 'start row to use Dim oStartRow As Integer oStartRow = 2 'number of rows to use Dim oRowlastcount As Long oRowlastcount = 5 For i = oStartRow To oRowlastcount oView1Member = GoExcel.CellValue(owbook, owSheet, "A" & i) oView2Member = GoExcel.CellValue(owbook, owSheet, "B" & i) oView3Member = GoExcel.CellValue(owbook, owSheet, "C" & i) currentfilename = GoExcel.CellValue(owbook, owSheet, "D" & i) MessageBox.Show(oView1Member, "partMember") ' MessageBox.Show(oView2Member, "partMember") ' MessageBox.Show(oView3Member, "partMember") ' MessageBox.Show(currentfilename, "Filename") oView1.ActiveMemberName = oView1Member oCrossSecdoc.SaveAs(oPathpdf & "\" & currentfilename & ".pdf", True) Next End Sub 'Sub ProcessView(drawView As DrawingView,partMember As String) ' Do something With the view Object ' MessageBox.Show(partMember, "partMember") ' MessageBox.Show(drawView.Name,"Drawing View Name") 'End Sub
