ejafari82LVK
66 Views, 0 Replies
Assistance Required with iLogic and iCopy Integration for Dynamic Assembly in Autodesk Inventor
Dear guys,
I hope this message finds you well.
I am currently working on a project in Autodesk Inventor where I have an assembly with a key feature: its main sketch and the dimensions of the constituent parts are dynamically adjusted using iLogic. This assembly is crucial to a larger building project, where I need to replicate it multiple times.
However, I've encountered a challenge when attempting to use iCopy for duplicating this assembly. When the dimensions of the main sketch are set as standard, iCopy fails to function correctly. To circumvent this, I altered the main sketch dimensions to driven dimensions, which allowed iCopy to operate as expected. Unfortunately, this modification leads to errors in iLogic, disrupting the dynamic nature of the assembly.
I am reaching out to seek your expertise and advice on how to resolve this issue. Specifically, I'm looking for guidance on how to effectively use iCopy with an iLogic-driven assembly without compromising the dynamic features driven by iLogic.
Thank you for your time and assistance. I am eager to resolve this issue and continue progressing with the project.
