knb7264
675 Views, 13 Replies
Check for flat patterns are created or not for all sheetmetal components in the assembly using iLogic
I have assembly having 500 parts and 150 of them are sheetmetal parts.
And I want to check if flat patterns have been created for all of the sheetmetal parts.
Can we check this using iLogic codes ?
emanuel.c
in reply to: knb7264
Do you only need to check if flat patterns exist?
Create flat patterns if not? Or give a message? Open that Document?
Can you expound a bit?
Yes, you can definitely do this and there are many posts on how to create flat patterns.
knb7264
Yes, I want to
1. Get list of the models which don't have flat patterns
2. Create Flat pattern if not created earlier.
emanuel.c
One more question, is it sufficient to create the flat patterns if they don't exist or do you also need a list of files which don't have flat patterns?
knb7264
Actually I need list so that first I can raise the revision of that parts in the vault and update properties.
emanuel.c
Here is something to start with. It writes the model paths which have missing flat patterns to a .txt file in the same location and with the same name as the Assembly you're running this code from. It also creates the flat patterns if they don't exist.
Dim oCompDef As SheetMetalComponentDefinition
Dim ErrorList As New ArrayList
ErrorCount = 0
'name TXT file by this assembly name and path
oFile = ThisDoc.PathAndFileName(False) & " - Checking for flat patterns" & ".txt"
'clear TXT file
System.IO.File.WriteAllText(oFile, "")
For Each oDoc As Document In ThisApplication.ActiveDocument.AllReferencedDocuments
	Dim oExists As Boolean = True
        If oDoc.IsModifiable = False Then Continue For
		If oDoc.SubType = "{9C464203-9BAE-11D3-8BAD-0060B0CE6BB4}" Then
		oCompDef = oDoc.ComponentDefinition
        If oCompDef.SurfaceBodies.Count = 0 Then Continue For
		If oCompDef.HasFlatPattern = True Then Continue For
		If oCompDef.HasFlatPattern = False Then ThisApplication.Documents.Open(oDoc.FullFileName, True)
		oExists = False
		Try
			oCompDef.Unfold
			oCompDef.FlatPattern.ExitEdit
			oDoc.Save
		Catch
			ErrorList.Add(oDoc.DisplayName)
			ErrorCount += 1
		Finally
			oDoc.Close(True)
		End Try
	End If
	'Open And append To an existing Text file
	Dim oAppend As System.IO.StreamWriter
	oAppend = IO.File.AppendText(oFile)
	If oExists = False Then
		oAppend.WriteLine(oDoc.FullDocumentName)
		oOpenTxtFile = True
	End If
	oAppend.Flush()
	oAppend.Close()
Next
If oOpenTxtFile = True Then
	MessageBox.Show("Opening Text File With Details", "You Have Some Missing Flat Patterns")
	ThisDoc.Launch(oFile)
Else
	MessageBox.Show("All components have flat patterns", "Great!")
End If
If ErrorCount > 0 Then
	oWrite = System.IO.File.CreateText(ThisDoc.PathAndFileName(False) + " Flat Pattern Errors.txt")
	oWrite.WriteLine(iProperties.Value("Project", "Part Number") + " Flat Pattern Errors")
	oWrite.WriteLine()
	For Each i In ErrorList
		oWrite.WriteLine(i)
	Next
	oWrite.Close
	Process.Start("notepad.exe", ThisDoc.PathAndFileName(False) + " Flat Pattern Errors.txt")
End If
'MessageBox.Show("All Flat Patterns Completed", "Flat Pattern Extractor", MessageBoxButtons.OK, MessageBoxIcon.Information, MessageBoxDefaultButton.Button1)
knb7264
in reply to: emanuel.c
@emanuel.c , Pardon me, but it is showing as below and creating blank text file and no flat patterns
m_baczewski
In my version of the code, it checks whether the components comprising the assembly have a flat pattern. If they do not, it saves them names to a .txt file located in the same location, and then creates a flat pattern.
Dim oDoc As Document
oDoc = ThisApplication.ActiveDocument
Dim countSheetWithoutFlatPattern As Integer = 0
Dim listOfSheetWithoutFlatPattern As String
If oDoc.SubType = "{E60F81E1-49B3-11D0-93C3-7E0706000000}"
	Dim oRefDoc As DocumentsEnumerator
	oRefDoc = oDoc.AllReferencedDocuments
	For Each element In oRefDoc
		If element.SubType = "{9C464203-9BAE-11D3-8BAD-0060B0CE6BB4}"
			Dim oSheetCompDef As SheetMetalComponentDefinition
			oSheetCompDef = element.ComponentDefinition
			If oSheetCompDef.HasFlatPattern = False
				oSheetCompDef.Unfold
				oSheetCompDef.FlatPattern.ExitEdit
				listOfSheetWithoutFlatPattern = listOfSheetWithoutFlatPattern & element.FullFileName & vbCrLf
				countSheetWithoutFlatPattern += 1
			End If
		End If
	Next
Else
	MsgBox("It`s not assembly document")
End If
If countSheetWithoutFlatPattern>0
	oWrite = System.IO.File.CreateText(ThisDoc.Path & "\SheetMetalWithoutFlatPattern.txt")
	oWrite.WriteLine(listOfSheetWithoutFlatPattern)
	oWrite.Close
	MsgBox("I saved in the file the components that didn`t have flat pattern. Now all components have flat pattern.")
Else
	MsgBox("All components has flat pattern")
End If
InventorVb.DocumentUpdate()
oDoc.Save2(True)
knb7264
in reply to: m_baczewski
@m_baczewski , Thanks for the codes, It is working good upto 1st part without flat pattern only then open it and create flat pattern for that. But after that it is showing error as below.
m_baczewski
Are all items checked-out from the Vault?
emanuel.c
You can try it again, I've changed a line there and it works well for me
knb7264
Yes
knb7264
@emanuel.c , Thank you very much ! It's perfect !!!
emanuel.c
You're welcome!
