01-18-2024
05:38 AM
- Mute
- Permalink
- Report
01-18-2024
05:38 AM
Thank you for a detailed reply.
Unfortunately I have to open the document with the visibility property set as True. Link below provides the reason why I have to do that.
https://forums.autodesk.com/t5/inventor-programming-ilogic/retrieve-view-cube-directions-from-an-ass...
I am able to close the document from an assembly (visible) if it wasn't in 'edit mode'. So my command works fine in assembly environment without 'edit mode' and part environment. I am looking for a solution to make it work in when 'edit mode' is active.
