- Mute
- Permalink
- Report
ilogic to open BOM (Bill of Materials) in inventor ??
Good morning everyone,
I am looking for some code to automatically open the BOM inside an Assembly ??
We have an ilogic code that runs to calculate totals quantities based on materials / cut size / cut length. After we run that code we open the BOM manually to review that the rule has done everything correctly.
I would like to automate the opening of the BOM.
Any assistance is appreciated.
Doug J
It's not easy maintaining this level of insanity !!!!!
- Mute
- Permalink
- Report
Dim c As ControlDefinition = ThisApplication.CommandManager.ControlDefinitions.Item("AssemblyBillOfMaterialsCmd") c.Execute
Arthur Knoors
Autodesk Affiliations:
- Mute
- Permalink
- Report
Hi @doug.johnston ,
See this past post on this topic that has some info about opening to a specific tab and editing the BOM, etc.
I hope this helps.
Curtis
