- Mute
- Permalink
- Report
iLogic Code to Export IFC file
Inventor 2020 soon to be updating to 2024.
I've developed a macro that efficiently exports both a Step and PDF file from an Inventor Drawing to a designated folder. However, I'm facing challenges in extending the functionality to include the export of an IFC file alongside the PDF and Step formats. Can someone assist by integrating the necessary code into the existing working code provided below?
I'm encountering an issue where the IFC file type is produced through the Environments tab of either a .ipt or .iam. Subsequently, I utilize the BIM Content add-in to generate the .ifc file. However, incorporating this process into the existing code proves challenging. Can someone provide assistance in seamlessly integrating the creation of the .ifc file using the Environments tab and BIM Content add-in within the current code framework?
iLogicVb.RunRule("Force Uppercase") ' Export PDF oPath = ThisDoc.Path oFileName = ThisDoc.FileName(False) ' without extension oPartNum = iProperties.Value("Project", "Part Number") oRevNum = iProperties.Value("Custom", "Revision") oTitle = iProperties.Value("Project", "Description") oPDFAddIn = ThisApplication.ApplicationAddIns.ItemById _ ("{0AC6FD96-2F4D-42CE-8BE0-8AEA580399E4}") oDocument = ThisApplication.ActiveDocument oContext = ThisApplication.TransientObjects.CreateTranslationContext oContext.Type = IOMechanismEnum.kFileBrowseIOMechanism oOptions = ThisApplication.TransientObjects.CreateNameValueMap oDataMedium = ThisApplication.TransientObjects.CreateDataMedium ' If oPDFAddIn.HasSaveCopyAsOptions(oDataMedium, oContext, oOptions) Then oOptions.Value("All_Color_AS_Black") = 1 oOptions.Value("Remove_Line_Weights") = 1 oOptions.Value("Vector_Resolution") = 400 oOptions.Value("Sheet_Range") = Inventor.PrintRangeEnum.kPrintAllSheets ' Get target folder path Dim oFolder As String Dim username As String username = Environ("USERNAME") oFolder = "C:\DRAWING " & "\" & oPartNum & "-" & oTitle If Not System.IO.Directory.Exists(oFolder) Then System.IO.Directory.CreateDirectory(oFolder) End If oFolder = System.IO.Path.Combine(oFolder, "Revision " & oRevNum) If Not System.IO.Directory.Exists(oFolder) Then System.IO.Directory.CreateDirectory(oFolder) End If Dim reviewNumber As Integer = 1 Dim reviewFolder As String Do reviewFolder = System.IO.Path.Combine(oFolder, "Approval " & reviewNumber) reviewNumber += 1 Loop While System.IO.Directory.Exists(reviewFolder) System.IO.Directory.CreateDirectory(reviewFolder) ' Set the PDF target file name Dim NewFileName As String Dim NewName As String NewFileName = System.IO.Path.Combine(reviewFolder, oPartNum & "_" & oRevNum & " - " & oTitle & ".pdf") NewName = oPartNum & "_" & oRevNum & " - " & oTitle & ".pdf" oDataMedium.FileName = NewFileName ' Publish PDF document oPDFAddIn.SaveCopyAs(oDocument, oContext, oOptions, oDataMedium) ' Set the STEP target file name Dim oDDoc As DrawingDocument = ThisDrawing.Document Dim oMDoc As Document = ThisDrawing.ModelDocument Dim oAddIns As ApplicationAddIns = ThisApplication.ApplicationAddIns Dim oSTEP As TranslatorAddIn For Each oAddIn As ApplicationAddIn In oAddIns If oAddIn.DisplayName = "Translator: STEP" Then oSTEP = oAddIn End If Next Dim oTO As TransientObjects = ThisApplication.TransientObjects oContext = oTO.CreateTranslationContext oContext.Type = IOMechanismEnum.kFileBrowseIOMechanism oOptions = oTO.CreateNameValueMap oDataMedium = oTO.CreateDataMedium Dim oStepFileName As String = iProperties.Value(oMDoc, "Project", "Part Number") & " " & iProperties.Value(oMDoc, "Project", "Description") ' Use the same folder for the STEP file oDataMedium.FileName = System.IO.Path.Combine(reviewFolder, oPartNum & "_" & oRevNum & " - " & oTitle & ".stp") If oSTEP.HasSaveCopyAsOptions(oMDoc, oContext, oOptions) Then ' Set application protocol. ' 2 = AP 203 - Configuration Controlled Design ' 3 = AP 214 - Automotive Design oOptions.Value("ApplicationProtocolType") = 3 ' Other options... 'oOptions.Value("IncludeSketches") = True 'oOptions.Value("export_fit_tolerance") = .000393701 'oOptions.Value("Author") = ThisApplication.GeneralOptions.UserName 'oOptions.Value("Authorization") = "" 'oOptions.Value("Description") = iProperties.Value(oMDoc, "Project", "Description") 'oOptions.Value("Organization") = iProperties.Value(oMDoc, "Document Summary Information", "Company") oSTEP.SaveCopyAs(oMDoc, oContext, oOptions, oDataMedium) End If MessageBox.Show("Location:" + vbCrLf + oFolder & "\" + vbCrLf + "" + vbCrLf + "PDF File Name:" + vbCrLf + NewName & vbCrLf & "STEP File Name:" + vbCrLf + NewName & ".stp", "PDF and STEP Saved")
