jordyCVWSE
in reply to: BM_Ashraf
Thank you for the quick reply. Since the time of the post i've been puzzling in the code and found a different solution:
Maybe it is a bit rough as i am not a coder, but it worked.
also added if there is no Rev number that it doesn't show.
Sub Main()
	oInvApp = ThisApplication
	Dim myDate As String = Now().ToString("dd-MM-yyyy")
	myDate = myDate.Replace(":","")  ' & " - " & TypeString
	userChoice = InputRadioBox("Defined the scope", "This Document", "All Open Documents", True, Title := "Defined the scope")
	UserSelectedActionList = New String(){"DWG & PDF", "PDF Only", "DWG Only"}
	UserSelectedAction = InputListBox("What action must be performed with selected views?", _
	UserSelectedActionList, UserSelectedActionList(0), Title := "Action to Perform", ListName := "Options")
	Select UserSelectedAction
	Case "DWG & PDF": UserSelectedAction = 3
	Case "PDF Only": UserSelectedAction = 1
	Case "DWG Only": UserSelectedAction = 2
	End Select
	If userChoice Then
		Call MakePDFFromDoc(oInvApp.ActiveDocument, myDate, UserSelectedAction)
	Else
		For Each oDoc In oInvApp.Documents
			If oDoc.DocumentType <> kDrawingDocumentObject Then Continue For
			Try
				If Len(oDoc.File.FullFileName) > 0 Then
					Call MakePDFFromDoc(oDoc, myDate, UserSelectedAction)
				End If
			Catch
			End Try
		Next
	End If
 End Sub
 Dim oInvApp As Inventor.Application
 Sub MakePDFFromDoc(ByRef oDocument As Document, DateString As String, UserSelectedAction As Integer)
	'oPath = oDocument.Path
	'oFileName = oDocument.FileName(False) 'without extension
	'oDocument = ThisApplication.ActiveDocument
	Dim sDescript As String = oDocument.PropertySets("Design Tracking Properties")("Description").Value
	Dim sRevnum As String = oDocument.PropertySets("Inventor Summary Information")("Revision Number").Value
	If oDocument.PropertySets("Inventor Summary Information")("Revision Number").Value = "" Then
		oREV = ""
ElseIf oDocument.PropertySets("Inventor Summary Information")("Revision Number").Value  IsNot  "" Then
		oREV= " REV "
End If
	oPDFAddIn = oInvApp.ApplicationAddIns.ItemById("{0AC6FD96-2F4D-42CE-8BE0-8AEA580399E4}")
	oContext = oInvApp.TransientObjects.CreateTranslationContext
	oContext.Type = IOMechanismEnum.kFileBrowseIOMechanism
	oOptions = oInvApp.TransientObjects.CreateNameValueMap
	oDataMedium = oInvApp.TransientObjects.CreateDataMedium
	oFullFileName = oDocument.File.FullFileName
	oPath = Left(oFullFileName, InStrRev(oFullFileName, "\")-1)
	oFileName = Right(oFullFileName, Len(oFullFileName)-InStrRev(oFullFileName, "\"))
'	oFilePart = Left(oFileName, InStrRev(oFileName, ".") - 1)
	oFilePart = Left(oFileName, InStrRev(oFileName, ".") - 1) & " " & sDescript & oREV & sRevNum
	'oRevNum = oDocument.iProperties.Value("Project", "Revision Number")
	'If oPDFAddIn.HasSaveCopyAsOptions(oDataMedium, oContext, oOptions) Then
	oOptions.Value("All_Color_AS_Black") = 0
	oOptions.Value("Remove_Line_Weights") = 1
	oOptions.Value("Vector_Resolution") = 400
	oOptions.Value("Sheet_Range") = Inventor.PrintRangeEnum.kPrintAllSheets
	'oOptions.Value("Custom_Begin_Sheet") = 2
	'oOptions.Value("Custom_End_Sheet") = 4
	' End If
	'get PDF target folder path
	'oFolder = Left(oPath, InStrRev(oPath, "\")) & "PDF"
	oFolder = oPath & "\Export DWG & PDF (" & DateString & ")"
	oDirectoryName = System.IO.Path.GetDirectoryName(oFullFileName)
	'Check for the PDF folder and create it if it does not exist
	If Not System.IO.Directory.Exists(oFolder) Then
		System.IO.Directory.CreateDirectory(oFolder)
	End If
	'Set the PDF target file name
	oDataMedium.FileName = oFolder & "\" & oFilePart & ".pdf"
	'Publish document
	If (UserSelectedAction = 1) Or (UserSelectedAction = 3) Then
		oPDFAddIn.SaveCopyAs(oDocument, oContext, oOptions, oDataMedium)'For PDF's
	End If
	If (UserSelectedAction = 2) Or (UserSelectedAction = 3) Then
		oDocument.SaveAs(oFolder & "\" & oFilePart & ".dwg", True) 'For DWG's
	End If
	'oDocument.SaveAs(oFolder & "\" & ThisDoc.ChangeExtension(".DWG"), True) 'For DWG's
	'------end of iLogic-------
 End Sub
