Michael.Navara
in reply to: J-Camper
If you need to add some new functionality to the PartDocument you have two possibilities.
  1. Create your own class which implements PartDocument interface. But this is too much work and it depends on API version. When you update API version you must check/update this implementation. I DON'T RECOMMEND THIS.
  2. Use extension methods. This allows you to add some new functionality without explicit implementation of PartDocument interface.
Part of sample implementation of PartDocument interface
Class MyPartDocument
    Implements PartDocument
    Dim p As PartDocument
    Public Sub New(p As PartDocument)
        p = p
    End Sub
    Public Sub Activate() Implements PartDocument.Activate
        p.Activate()
    End Sub
    Public Sub Close(Optional SkipSave As Boolean = False) Implements PartDocument.Close
        p.Close(SkipSave)
    End Sub
    Public Sub Save() Implements PartDocument.Save
        p.Save()
    End Sub
Sample of extension method
Class ClassInYourAddin
    Sub SampleUsageOfExtensionMethod()
        Dim fileNameWithoutExtension As String = p.FileNameWithoutExtension()
    End Sub
End Class
Public Module PartDocExtensions
    <Extension>
    Public Function FileNameWithoutExtension(part As PartDocument) As String
        Return System.IO.Path.GetFileNameWithoutExtension(part.FullFileName)
    End Function
End Module
