01-04-2024
09:29 AM
- Mute
- Permalink
- Report
01-04-2024
09:29 AM
Hi @aurel_e. Something like this maybe? If there are multiple of the same sub assembly within the main assembly, and it has multiple ModelStates, and some of those component instances are set to different ModelStates, then this code might need to also include a List(Of String) to keep track of each document's FullFileName while checking. The FullDocumentName will include the name of the ModelState, so that would not be a good choice, depending on your needs.
Sub Main
If ThisDoc.Document.DocumentType <> DocumentTypeEnum.kAssemblyDocumentObject Then Return
Dim oADoc As AssemblyDocument = ThisDoc.Document
Dim oRefDocs As DocumentsEnumerator = oADoc.AllReferencedDocuments
Dim iCount As Integer = 0
For Each oRefDoc As Inventor.Document In oRefDocs
If oRefDoc.DocumentType = DocumentTypeEnum.kAssemblyDocumentObject Then
iCount = iCount + 1
End If
Next
MsgBox("There are " & iCount & " unique sub assemblies in this assembly.", vbInformation, "iLogic")
End Sub
If this solved your problem, or answered your question, please click ACCEPT SOLUTION .
Or, if this helped you, please click (LIKE or KUDOS)
Wesley Crihfield
(Not an Autodesk Employee)
