01-04-2024
06:44 AM
- Mute
- Permalink
- Report
01-04-2024
06:44 AM
Hi @davidt162003. Content Center files are usually ReadOnly. That is likely why it is throwing an error when you try to copy an Appearance asset from the appearance library down into that document. That is just the nature of Content Center generated models. But you may be able to copy that model file out of the Content Center storage area (which is seen as a Library), and put it out in your regular model file area, then change a couple things to dis-associate it from the Content Center. Then you may be able to add another appearance to the document and use that to change the appearance of the model.
Wesley Crihfield
(Not an Autodesk Employee)
