A.Acheson
in reply to: jthzzang1KQJ5G
Hi @jthzzang1KQJ5G
Can you indicate a few areas where your having difficulty? Any error messages, missing functionality etc?
I see in one area you are using an ilogic API snippet that will only work from the document the rule is launched from in this case the assembly.
Dim oDocNumber As String = ThisDoc.FileName(False)
If you need to get the filename you can use IO.Path.GetFileNameWithoutExtension() see help page here
To get filename of referenced document using System.IO methods.
Dim fileName as String = IO.Path.GetFileNameWithoutExtension(refDoc.FullFileName)
Regards
Alan
