12-28-2023
08:35 AM
- Mute
- Permalink
- Report
12-28-2023
08:35 AM
Here is a a quick update to @A.Acheson's example.
When I tested his version, my project didn't have a workspace, so this version handles that and uses the project file folder.
This version also closes the opened files, and opens the file with the target part number visibly.
I hope this helps.
Curtis
Dim prjfile As DesignProject = ThisApplication.DesignProjectManager.ActiveDesignProject Dim prjfolder As String = prjfile.WorkspacePath & "\" If prjfolder = "\" Then prjfolder = IO.Path.GetDirectoryName(prjfile.FullFileName) End If Dim projectDir As New IO.DirectoryInfo(prjfolder) Dim workFiles As IEnumerable(Of String) workFiles = IO.Directory.EnumerateFiles(prjfolder, "*.ipt", 1) '1 searches subfolders, use 0 for top level only Dim doc As Document Dim targetdoc As Document For Each fi In workFiles doc = ThisApplication.Documents.Open(fi, False) Logger.Info("File Opened : " & doc.fullfilename) Try Dim designProp As PropertySet = doc.PropertySets.Item("Design Tracking Properties") Dim partNo As String = designProp.Item("Part Number").Value If partNo = "1234" Then Logger.Info("Found partNo : " & partNo) 'open visibly targetdoc = ThisApplication.Documents.Open(fi, True) End If Catch ex As Exception Logger.Info(ex.Message & "-" & "Error Getting Part Number") End Try If Not doc Is ThisDoc.Document And Not doc Is targetdoc Then Logger.Info("File Closed : " & doc.fullfilename) doc.Close End If If Not targetdoc Is Nothing Then Exit Sub ' quit looking for files if target is found Next
