- Mute
- Permalink
- Report
I am attempting to Randomly Generate a Drawing/Program number and add it to an excel spreadsheet, the hope is that my rule would generate the number, check the spreadsheet to make sure it doesn't exist then add the new number in the next available row, if the number does exist a message box prompts the user to generate a new number. Parts of the code work however I am failing measurably at writing to the spread sheet.
Thanks in advance
Brent
- Mute
- Permalink
- Report
Hey Brent,
I have not had much luck dealing with Excel file either. But looking at the helper note, it looks like they have ".xls" not ".xlsx". I am sure it isn't that simple but throwing it out there.
Have a great one,
Chris
- Mute
- Permalink
- Report
Hi Chris,
Unfortunately, that wasn't the problem. I was able to finally write to Excel however I found that an insistence of Excel was left running when looking at task manager for each part number created and when pushing Parameters from an
assembly it slowed the process to a near stop. My thoughts for now, while a table with the newly created part numbers, description, user & date would be useful, the odds of repeating a 10-digit alpha number using both upper and lower case is pretty slim.
Brent
Brent
- Mute
- Permalink
- Report
Hi @bbrumfield
You should open and close the excel workbook before and after your operation is completed. The snippets for this are in the ilogic editor. If you need more control over the process then you can go the VB.NET excel dll route where you have the same power as VBA macro has.
Or if this helped you, please, click (like)
Regards
Alan
- Mute
- Permalink
- Report
Update 12/30/2023
I was mistaken, excelApp.Visible = True or False and excelApp.Quit() make no difference the excel app continues to show in task manger. When pushing Parameters from an assembly or simply creating a new Part I end up with an instance showing in task manager for every part.
Hi A.Acheson,
I was able to kill the process by changing excel.app.visible to true. I'm still uncertain if the rule is actually checking to see if the part number exists. My thoughts are that I would trigger the rule on creation of a new part and create some variation of the Code to run on sheet metal parts only when pushing Parameters from an Assembly.
See Code Below (borrowed and modified from a snippet by Curtis Waguespack)
Sub Main() Dim oDoc As Document = ThisDoc.Document iLogicVb.UpdateWhenDone = True Top: oFile = "Path\File.xlsx" 'define Excel Application object excelApp = CreateObject("Excel.Application") 'set Excel to run invisibly, change to true if you want to run it visibly excelApp.Visible = True 'suppress prompts (such as the compatibility checker) excelApp.DisplayAlerts = False Dim xCharArray() As Char = "abcdefghijklmnopqrstuvwxyzABCDEFGHIJKLMNOPQRSTUVWXYZ".ToCharArray Dim xNoArray() As Char = "0123456789".ToCharArray Dim xGenerator As System.Random = New System.Random() Dim xStr As String = String.Empty While xStr.Length < 10 If xGenerator.Next(0, 2) = 0 Then xStr &= xCharArray(xGenerator.Next(0, xCharArray.Length)) Else xStr &= xNoArray(xGenerator.Next(0, xNoArray.Length)) End If End While oValueToMatch = xStr Dim oProName1 As String = "Default Table Part Number" Dim oProName2 As String = "Default Table Description" Dim oProSet As Inventor.PropertySet = ThisApplication.ActiveDocument.PropertySets.Item("User Defined Properties") Dim oProp As Inventor.Property Try oProp = oProSet(oProName1) oProp = oProSet(oProName2) Catch oProp = oProSet.Add("",oProName1) oProp = oProSet.Add("",oProName2) End Try If iProperties.Value("Custom","Default Table Part Number")= "" Then GoTo DescNeeded Else If iProperties.Value("Custom","Default Table Part Number") > "" Then GoTo UserTime End If DescNeeded : Desc = InputBox("Excel Table Description, ie: FT90FM, End Cap", "Enter Description Here") iProperties.Value("Custom", "Default Table Part Number") = xStr iProperties.Value("Custom", "Default Table Description") = Desc oTime = Now.ToShortDateString oUser = iProperties.Value("Custom", "ModifiedBy") oDescriptionToMatch = Desc iProperties.Value("Project","Part Number") = xStr Goto StartPNAdd UserTime : iProperties.Value("Project","Part Number") = xStr oTime = Now.ToShortDateString oUser = iProperties.Value("Custom", "ModifiedBy") oDescriptionToMatch = iProperties.Value("Custom", "Default Table Description") StartPNAdd: If Dir(oFile) <> "" Then 'workbook exists, open it oWB = excelApp.Workbooks.Open(oFile) oWS = oWB.Worksheets(1) Else Return 'exit rule End If 'Loop through the rows In column A For iRow = 2 To oWS.UsedRange.Rows.Count 'get value of the cell oCellValue = oWS.Cells(iRow, "A" ).Value If oCellValue = oValueToMatch Then oWS.Cells(iRow, "A").Value = oCellValue + 1 oFound = True Goto Top Else oFound = False End If Next iRow If oFound = False Then oWS.Cells(oWS.UsedRange.Rows.Count + 1, "A").Value = oValueToMatch oWS.Cells(oWS.UsedRange.Rows.Count, "B").Value = oDescriptionToMatch oWS.Cells(oWS.UsedRange.Rows.Count, "C").Value = oTime oWS.Cells(oWS.UsedRange.Rows.Count, "D").Value = oUser End If 'set all of the columns to autofit excelApp.Columns.AutoFit 'save the file oWB.Save oDoc.Save 'close the workbook and the Excel Application oWB.Close excelApp.Quit() 'excelApp = Nothing End Sub Thanks,
Brent
- Mute
- Permalink
- Report
Revisiting my original Post:
I believe all issues are resolved including verifying that the new number isn't a duplicate and killing excel from running in processes.
Brent
