- Mute
- Permalink
- Report
Hi All
I am having issues with the following code. The issue is, when the height is less than the width the code works as intended, but when the height is greater than the width the "Feature.IsActive("LeftBottomFace") = False" & "Feature.IsActive("RightBottomFace") = False" rules are being ignored. Any ideas as to why this is happening would be greatly appreciated.
Parameter("TopCut") = Parameter("UnderlapCut") Parameter("TopFlange") = Parameter("UnderlapFlange") Parameter("TopHoleSize") = 10 Parameter("BottomCut") = Parameter("OverlapCut") Parameter("BottomFlange") = Parameter("OverlapFlange") Parameter("BottomHoleSize") = 8 Parameter("LeftCut") = Parameter("UnderlapCut") Parameter("LeftFlange") = Parameter("UnderlapFlange") Parameter("LeftHoleSize") = 8 Parameter("RightCut") = Parameter("UnderlapCut") Parameter("RightFlange") = Parameter("UnderlapFlange") Parameter("RightHoleSize") = 10 Feature.IsActive("LeftTopFace") = True Parameter("LTHoleSize") = 8 Feature.IsActive("LeftBottomFace") = False Feature.IsActive("RightTopFace") = True Parameter("RTHoleSize") = 10 Feature.IsActive("RightBottomFace") = False Feature.IsActive("TempFixR") = True Feature.IsActive("TempFixL") = False iProperties.Value("Custom", "Type") = "RECESSED FIX" iProperties.Value("Custom", "Joint") = "INTER STARTER" iProperties.Value("Custom", "Lay") = "L TO R" InventorVb.DocumentUpdate()
- Mute
- Permalink
- Report
Hi @scottbudge
Do you have the pseudo logic laid out to switch the features on and off?
Or if this helped you, please, click (like)
Regards
Alan
- Mute
- Permalink
- Report
Hi Sorry I am new to this and self taught, what do you mean when you say "pseudo logic" ?
- Mute
- Permalink
- Report
Something like this? Do you have this logic built out to control your features?
If height <width Then
Feature.IsActive("LeftBottomFace") = True
Feature.IsActive("RightBottomFace") = True
ElseIf height >width Then
EndIf
Regards
Alan
- Mute
- Permalink
- Report
I have something similar in my "Parameters" rule (see below), would it be better to incorporate as you have suggested?
If Parameter("Cassette_Width") > Parameter("Cassette_Height") iProperties.Value("Custom", "Orientation") = "HORIZONTAL" iProperties.Value("Custom", "ProgramHeight") = Parameter("Cassette_Height") iProperties.Value("Custom", "ProgramWidth") = Parameter("Cassette_Width") iProperties.Value("Custom", "Gauge") = Parameter("Thickness") iProperties.Value("Custom", "Height") = Parameter("Cassette_Height") iProperties.Value("Custom", "Width") = Parameter("Cassette_Width") iProperties.Value("Custom", "StiffLength") = Parameter("Cassette_Height")-10 Length = SheetMetal.FlatExtentsLength Girth = SheetMetal.FlatExtentsWidth iProperties.Value("Custom", "Length")= Round(Length,1) iProperties.Value("Custom", "Girth") = Round(Girth, 1) iProperties.Value("Custom", "Depth") = Parameter("Depth") iProperties.Value("Custom", "Path") = ThisDoc.Path ElseIf Parameter("Cassette_Height") > Parameter("Cassette_Width") iProperties.Value("Custom", "Orientation") = "VERTICAL" iProperties.Value("Custom", "ProgramHeight") = Parameter("Cassette_Width") iProperties.Value("Custom", "ProgramWidth") = Parameter("Cassette_Height") iProperties.Value("Custom", "Gauge") = Parameter("Thickness") iProperties.Value("Custom", "Height") = Parameter("Cassette_Height") iProperties.Value("Custom", "Width") = Parameter("Cassette_Width") iProperties.Value("Custom", "StiffLength") = Parameter("Cassette_Width")-10 Length = SheetMetal.FlatExtentsLength Girth = SheetMetal.FlatExtentsWidth iProperties.Value("Custom", "Length")= Round(Length,1) iProperties.Value("Custom", "Girth") = Round(Girth, 1) iProperties.Value("Custom", "Depth") = Parameter("Depth") iProperties.Value("Custom", "Path") = ThisDoc.Path ElseIf Parameter("Cassette_Width") = Parameter("Cassette_Height") iProperties.Value("Custom", "Orientation") = "VERTICAL" iProperties.Value("Custom", "ProgramHeight") = Parameter("Cassette_Width") iProperties.Value("Custom", "ProgramWidth") = Parameter("Cassette_Height") iProperties.Value("Custom", "Gauge") = Parameter("Thickness") iProperties.Value("Custom", "Height") = Parameter("Cassette_Height") iProperties.Value("Custom", "Width") = Parameter("Cassette_Width") iProperties.Value("Custom", "StiffLength") = Parameter("Cassette_Width")-10 Length = SheetMetal.FlatExtentsLength Girth = SheetMetal.FlatExtentsWidth iProperties.Value("Custom", "Length")= Round(Length,1) iProperties.Value("Custom", "Girth") = Round(Girth, 1) iProperties.Value("Custom", "Depth") = Parameter("Depth") iProperties.Value("Custom", "Path") = ThisDoc.Path End If
The above code is driven by this master code that reads an excel spreadsheet
'Dim exl As String 'exl = SharedVariable("exl") xlspath = ThisDoc.Path & "/ORDER FORM.xlsx" Dim oExcelRow As String oExcelRow = iProperties.Value("Custom", "ExcelRow") Dim oExcelRow2 As String oExcelRow2 = oExcelRow + 1 iProperties.Value("Custom", "ExcelRow") = oExcelRow2 'GoExcel.Open(sharedvariable("exl")) 'A = CASSETTE ID 'B = CASSETTE QTY 'C = CASSETTE WIDTH 'D = CASSETTE HEIGHT 'E = CASSETTE LENGTH 'F = CASSETTE GIRTH 'G = FACADE TYPE 'H = CASSETTE JOINT TYPE 'I = LAY DIRECTION 'K = CASSETTE DEPTH 'K = TOP HOLE CENTRES (A) 'L = BOTTOM HOLE CENTRES (A) 'M = MACHINE ROUTE 'N = SAP NO. 'O = LINE NO. 'P = NOTES 'Q = STIFFENERS '//////////////////////////////////////////////////////////////////////////////////////////////////////// '// Cassette ID iProperties.Value("Project", "Part Number") = GoExcel.CellValue(xlspath, "Sheet1","A" & iProperties.Value("Custom", "ExcelRow")) If GoExcel.CellValue("A" & iProperties.Value("Custom", "ExcelRow")) = Nothing MessageBox.Show("CASSETTE NUMBER CELL BLANK", "Error") iProperties.Value("Project", "Part Number") = "ERROR" End If '//////////////////////////////////////////////////////////////////////////////////////////////////////// '// Cassette Qty iProperties.Value("Custom", "Qty") = GoExcel.CellValue(xlspath, "Sheet1","B" & iProperties.Value("Custom", "ExcelRow")) If GoExcel.CellValue("B" & iProperties.Value("Custom", "ExcelRow")) = Nothing MessageBox.Show("CASSETTE QTY CELL BLANK", "Error") iProperties.Value("Custom", "Qty") = "ERROR" End If '//////////////////////////////////////////////////////////////////////////////////////////////////////// '// Cassette Height Parameter("Cassette_Height") = GoExcel.CellValue(xlspath, "Sheet1","D" & iProperties.Value("Custom", "ExcelRow")) If GoExcel.CellValue("D" & iProperties.Value("Custom", "ExcelRow")) = Nothing MessageBox.Show("CASSETTE HEIGHT CELL BLANK", "Error") Parameter("Cassette_Height") = 600 End If '//////////////////////////////////////////////////////////////////////////////////////////////////////// '// Cassette Width Parameter("Cassette_Width") = GoExcel.CellValue(xlspath, "Sheet1","C" & iProperties.Value("Custom", "ExcelRow")) If GoExcel.CellValue("C" & iProperties.Value("Custom", "ExcelRow")) = Nothing MessageBox.Show("CASSETTE WIDTH CELL BLANK", "Error") Parameter("Cassette_Width") = 600 End If '//////////////////////////////////////////////////////////////////////////////////////////////////////// '// Cassette Depth iProperties.Value("Custom", "Depth") = GoExcel.CellValue(xlspath, "Sheet1","K" & iProperties.Value("Custom", "ExcelRow")) Parameter("Depth2") = iProperties.Value("Custom", "Depth")+1 '//////////////////////////////////////////////////////////////////////////////////////////////////////// '// Cassette Joint Type iProperties.Value("Summary", "Title") = GoExcel.CellValue(xlspath, "Sheet1","H" & iProperties.Value("Custom", "ExcelRow")) If iProperties.Value("Summary", "Title") = "Bottom Starter" iProperties.Value("Custom", "Type") = "BOTTOM STARTER" ElseIf iProperties.Value("Summary", "Title") = "Bottom Intermediate" iProperties.Value("Custom", "Type") = "BOTTOM INTERMEDIATE" ElseIf iProperties.Value("Summary", "Title") = "Bottom End" iProperties.Value("Custom", "Type") = "BOTTOM END" ElseIf iProperties.Value("Summary", "Title") = "Inter Starter" iProperties.Value("Custom", "Type") = "INTERMEDIATE STARTER" ElseIf iProperties.Value("Summary", "Title") = "Intermediate" iProperties.Value("Custom", "Type") = "INTERMEDIATE" ElseIf iProperties.Value("Summary", "Title") = "Inter End" iProperties.Value("Custom", "Type") = "INTERMEDIATE END" ElseIf iProperties.Value("Summary", "Title") = "Top Starter" iProperties.Value("Custom", "Type") = "TOP STARTER" ElseIf iProperties.Value("Summary", "Title") = "Top Intermediate" iProperties.Value("Custom", "Type") = "TOP INTER" ElseIf iProperties.Value("Summary", "Title") = "Top End" iProperties.Value("Custom", "Type") = "TOP END" ElseIf GoExcel.CellValue(xlspath, "Sheet1","G" & iProperties.Value("Custom", "ExcelRow")) = Nothing MessageBox.Show("CASSETTE TYPE CELL BLANK", "Error") iProperties.Value("Summary", "Title") = "ERROR" End If '//////////////////////////////////////////////////////////////////////////////////////////////////////// '// Cassette Lay Direction iProperties.Value("Custom", "Lay") = GoExcel.CellValue(xlspath, "Sheet1","I" & iProperties.Value("Custom", "ExcelRow")) '//Bottom Starter If iProperties.Value("Summary", "Title") = "Bottom Starter" If iProperties.Value("Custom", "Lay") = "L to R" iLogicVb.RunRule("BS-LtoR") ElseIf iProperties.Value("Custom", "Lay") = "R to L" iLogicVb.RunRule("BS-RtoL") ElseIf iProperties.Value("Custom", "Lay") = Nothing MessageBox.Show("LAY DIRECTION CELL BLANK", "Error") iProperties.Value("Custom", "Lay") = "ERROR" iLogicVb.RunRule("RESET") End If '//Bottom Inter ElseIf iProperties.Value("Summary", "Title") = "Bottom Intermediate" If iProperties.Value("Custom", "Lay") = "L to R" iLogicVb.RunRule("BI-LtoR") ElseIf iProperties.Value("Custom", "Lay") = "R to L" iLogicVb.RunRule("BI-RtoL") ElseIf iProperties.Value("Custom", "Lay") = Nothing MessageBox.Show("LAY DIRECTION CELL BLANK", "Error") iProperties.Value("Custom", "Lay") = "ERROR" iLogicVb.RunRule("RESET") End If '//Bottom End ElseIf iProperties.Value("Summary", "Title") = "Bottom End" If iProperties.Value("Custom", "Lay") = "L to R" iLogicVb.RunRule("BE-LtoR") ElseIf iProperties.Value("Custom", "Lay") = "R to L" iLogicVb.RunRule("BE-RtoL") ElseIf iProperties.Value("Custom", "Lay") = Nothing MessageBox.Show("LAY DIRECTION CELL BLANK", "Error") iProperties.Value("Custom", "Lay") = "ERROR" iLogicVb.RunRule("RESET") End If '//Inter Starter ElseIf iProperties.Value("Summary", "Title") = "Inter Starter" If iProperties.Value("Custom", "Lay") = "L to R" iLogicVb.RunRule("IS-LtoR") ElseIf iProperties.Value("Custom", "Lay") = "R to L" iLogicVb.RunRule("IS-RtoL") ElseIf iProperties.Value("Custom", "Lay") = Nothing MessageBox.Show("LAY DIRECTION CELL BLANK", "Error") iProperties.Value("Custom", "Lay") = "ERROR" iLogicVb.RunRule("RESET") End If '//Intermediate ElseIf iProperties.Value("Summary", "Title") = "Intermediate" If iProperties.Value("Custom", "Lay") = "L to R" iLogicVb.RunRule("II-LtoR") ElseIf iProperties.Value("Custom", "Lay") = "R to L" iLogicVb.RunRule("II-RtoL") ElseIf iProperties.Value("Custom", "Lay") = Nothing MessageBox.Show("LAY DIRECTION CELL BLANK", "Error") iProperties.Value("Custom", "Lay") = "ERROR" iLogicVb.RunRule("RESET") End If '//Inter End ElseIf iProperties.Value("Summary", "Title") = "Inter End" If iProperties.Value("Custom", "Lay") = "L to R" iLogicVb.RunRule("IE-LtoR") ElseIf iProperties.Value("Custom", "Lay") = "R to L" iLogicVb.RunRule("IE-RtoL") ElseIf iProperties.Value("Custom", "Lay") = Nothing MessageBox.Show("LAY DIRECTION CELL BLANK", "Error") iProperties.Value("Custom", "Lay") = "ERROR" iLogicVb.RunRule("RESET") End If '//Top Starter ElseIf iProperties.Value("Summary", "Title") = "Top Starter" If iProperties.Value("Custom", "Lay") = "L to R" iLogicVb.RunRule("TS-LtoR") ElseIf iProperties.Value("Custom", "Lay") = "R to L" iLogicVb.RunRule("TS-RtoL") ElseIf iProperties.Value("Custom", "Lay") = Nothing MessageBox.Show("LAY DIRECTION CELL BLANK", "Error") iProperties.Value("Custom", "Lay") = "ERROR" iLogicVb.RunRule("RESET") End If '//Top Inter ElseIf iProperties.Value("Summary", "Title") = "Top Intermediate" If iProperties.Value("Custom", "Lay") = "L to R" iLogicVb.RunRule("TI-LtoR") ElseIf iProperties.Value("Custom", "Lay") = "R to L" iLogicVb.RunRule("TI-RtoL") ElseIf iProperties.Value("Custom", "Lay") = Nothing MessageBox.Show("LAY DIRECTION CELL BLANK", "Error") iProperties.Value("Custom", "Lay") = "ERROR" iLogicVb.RunRule("RESET") End If '// Top End ElseIf iProperties.Value("Summary", "Title") = "Top End" If iProperties.Value("Custom", "Lay") = "L to R" iLogicVb.RunRule("TE-LtoR") ElseIf iProperties.Value("Custom", "Lay") = "R to L" iLogicVb.RunRule("TE-RtoL") ElseIf iProperties.Value("Custom", "Lay") = Nothing MessageBox.Show("LAY DIRECTION CELL BLANK", "Error") iProperties.Value("Custom", "Lay") = "ERROR" iLogicVb.RunRule("RESET") End If '// NO TYPE ElseIf iProperties.Value("Summary", "Title") = "ERROR" iLogicVb.RunRule("RESET") End If '//////////////////////////////////////////////////////////////////////////////////////////////////////// ''// Top Hole Centres 'Parameter("TopHoleGap") = GoExcel.CellValue(xlspath, "Sheet1","K" & iProperties.Value("Custom", "ExcelRow")) ''//////////////////////////////////////////////////////////////////////////////////////////////////////// ''// Bottom Hole Centres 'Parameter("BottomHoleGap") = GoExcel.CellValue(xlspath, "Sheet1","K" & iProperties.Value("Custom", "ExcelRow")) ''//////////////////////////////////////////////////////////////////////////////////////////////////////// ''// Left Hole Centres 'Parameter("LeftHoleGap") = GoExcel.CellValue(xlspath, "Sheet1","L" & iProperties.Value("Custom", "ExcelRow")) ''//////////////////////////////////////////////////////////////////////////////////////////////////////// ''// Right Hole Centres 'Parameter("RightHoleGap") = GoExcel.CellValue(xlspath, "Sheet1","L" & iProperties.Value("Custom", "ExcelRow")) '//////////////////////////////////////////////////////////////////////////////////////////////////////// InventorVb.DocumentUpdate() '//////////////////////////////////////////////////////////////////////////////////////////////////////// '// Flat Pattern Extents '//Vertical Cassette If Parameter("Cassette_Height") >= Parameter("Cassette_Width") iProperties.Value("Custom", "Orientation") = "VERTICAL" Length = SheetMetal.FlatExtentsLength iProperties.Value("Custom", "Girth") = Round(Length, 1) Girth = SheetMetal.FlatExtentsWidth iProperties.Value("Custom", "Length") = Round(Girth, 1) GoExcel.CellValue(xlspath, "Sheet1","E" & iProperties.Value("Custom", "ExcelRow")) = iProperties.Value("Custom", "Length") GoExcel.CellValue(xlspath, "Sheet1","F" & iProperties.Value("Custom", "ExcelRow")) = iProperties.Value("Custom", "Girth") '//Horizontal Cassette Else iProperties.Value("Custom", "Orientation") = "HORIZONTAL" Length = SheetMetal.FlatExtentsLength iProperties.Value("Custom", "Length") = Round(Length, 1) Girth = SheetMetal.FlatExtentsWidth iProperties.Value("Custom", "Girth") = Round(Girth, 1) GoExcel.CellValue(xlspath, "Sheet1","E" & iProperties.Value("Custom", "ExcelRow")) = iProperties.Value("Custom", "Length") GoExcel.CellValue(xlspath, "Sheet1","F" & iProperties.Value("Custom", "ExcelRow")) = iProperties.Value("Custom", "Girth") End If '//////////////////////////////////////////////////////////////////////////////////////////////////////// '// Other Stuff iProperties.Value("Custom", "Machine Route") = GoExcel.CellValue(xlspath, "Sheet1", "M" & iProperties.Value("Custom", "ExcelRow")) iProperties.Value("Custom", "SAP Order No.") = GoExcel.CellValue(xlspath, "Sheet1", "N" & iProperties.Value("Custom", "ExcelRow")) iProperties.Value("Custom", "LineNo.") = GoExcel.CellValue(xlspath, "Sheet1", "O" & iProperties.Value("Custom", "ExcelRow")) iProperties.Value("Custom", "Stiffened") = GoExcel.CellValue(xlspath, "Sheet1", "T" & iProperties.Value("Custom", "ExcelRow")) If iProperties.Value("Custom", "Stiffened") = "Stiffened" iProperties.Value("Custom", "StiffQty") = GoExcel.CellValue(xlspath, "Sheet1", "U" & iProperties.Value("Custom", "ExcelRow")) * iProperties.Value("Custom", "Qty") ElseIf iProperties.Value("Custom", "Stiffened") = "Un-Stiffened" iProperties.Value("Custom", "StiffQty") = 0 End If '//////////////////////////////////////////////////////////////////////////////////////////////////////// GoExcel.Save iLogicForm.Show("NextCassette")
- Mute
- Permalink
- Report
I found the issue, a pattern feature was relying on the feature I wanted to suppress so I simply selected a different axis for my direction and it solved the problem.
