vpeuvion
in reply to: m.huester
I'm using the latest version of Inventor 2023.
It works on my side, I can no longer reproduce the error.
Can you try this modification:
Catch
  oPara.AddByValue("SML", "Wert1", kTextUnits)
  MultiValue.SetList("SML", "Wert1", "Wert2", "Wert3")
End Try
I broke the code into two parts:
- Create the parameter if it does not exist:
oPara = ThisApplication.ActiveDocument.ComponentDefinition.Parameters.UserParameters
Try
  Param = Parameter.Param("SML")
Catch
End Try
 - Modify the value of the existing parameter:
Parameter.Param("SML").Value = InputListBox("bitte doppelklick auf Auswahl", MultiValue.List("SML"), SML, Title := "SML nach Vornummer", ListName := "Liste")
iLogicVb.UpdateWhenDone = True
Parameter.UpdateAfterChange = True
InventorVb.DocumentUpdate()
If you test each part separately, what results do you get?
Vincent.
