- Mute
- Permalink
- Report
Hi @ngnam1988,
With this code it should work, but since it is not updated I think we have found a bug in the API here.
Dim p As PartDocument = ThisDoc.Document
Dim td As Inventor.ModelAnnotation
For Each td In p.ComponentDefinition.ModelAnnotations
If td.Type = ObjectTypeEnum.kModelLeaderNoteObject Then
Dim ml As ModelLeaderNote
ml = td
MsgBox(ml.Definition.Text.WidthScale)
Dim mld As ModelLeaderNoteDefinition = ml.Definition
mld.Text.WidthScale = 2
MsgBox(mld.Text.WidthScale)
mld.Text.WidthScale = 3
mld.Text.WidthScale = 4
MsgBox (mld.Text.WidthScale)
End If
Next
@johnsonshiue could you and your team take a look at this and maybe confirm that the above is the case.
Please see the attached video where I change the WidthScale from 1 to 2 to 3 to 4 and it does not update.
Arthur Knoors
Autodesk Affiliations:
