- Mute
- Permalink
- Report
Hi folks,
Here in the folowing example, I'm using the command manager to pick a surface (pipe) to add a component.
I'm creating the component, adding to assembly, placing the constraints around the pipe, etc.
The last constraint that I didn't add is in the axis of the pipe. The component can move left & right according to the axis. As for now it is landing randomly along the axis. Whould there be somehow a way to get the 3D point where I clicked using the commandManager.Pick method ?
Thank you & kind regards,
FINET L.
If this post solved your question, please kindly mark it as "Solution"
If this post helped out in any way to solve your question, please drop a "Like"Solved! Go to Solution.
- Mute
- Permalink
- Report
..Dug in the documentation & found out what I was looking for.
Here is the code I ended up with :
Private Class Testing
Private Selecting As Boolean
Sub Main()
Dim i As InteractionEvents = ThisApplication.CommandManager.CreateInteractionEvents
i.InteractionDisabled = False
Dim selectEvents As Inventor.SelectEvents = i.SelectEvents()
AddHandler selectEvents.OnSelect, AddressOf oSelectEvents_OnSelect
i.Start
Selecting = True
While Selecting = True
ThisApplication.UserInterfaceManager.DoEvents()
End While
i.Stop
End Sub
Private Sub oSelectEvents_OnSelect(ByVal JustSelectedEntities As ObjectsEnumerator, ByVal SelectionDevice As SelectionDeviceEnum, ByVal ModelPosition As Point, ByVal ViewPosition As Point2d, ByVal View As View)
MsgBox("X :" & Round(ModelPosition.X, 2) & " Y :" &Round(ModelPosition.Y, 2) & " Z :" & Round(ModelPosition.Z, 2))
Selecting = False
End Sub
End Class
Kind regards,
FINET L.
