Hi @WCrihfield
Main Rule
AddReference "System.Data"
AddReference "System.Xml"
AddReference "Microsoft.Office.Interop.Excel.dll"
AddVbFile "...\mLog.vb"
AddVbFile "...\cMagnum.vb"
Class ThisRule
   Private oMagnum As cMagnum
   Sub Main
      StartLog
      oMagnum = New cMagnum(Logger, arrayRiga, transcodifica)
   End Sub
End Class
mLog.vb
Imports Autodesk.iLogic.Core
Imports Autodesk.iLogic.Interfaces
Imports Autodesk.Inventor
Imports System
Public Module mLog
    Private iLogicAuto As Autodesk.iLogic.Interfaces.IiLogicAutomation
    Private Logger As Autodesk.iLogic.Interfaces.IRuleLogger
    'Public logCtrl As LogControl
    'Public Log As IRuleLogger
    Public Sub StartLog()'(startMarker As String)
		Logger.Debug("TEST MODULO")
        'Log.Debug(startMarker)
		'Log.Trace("**Class cLog - StartLog")
        'Log.Info(" Log regola lanciata alle " & DateTime.Now)
    End Sub
    Public Sub EndLog(startMarker As String, nomeRegola As String, Optional percorsoLogCompleto As String = "...\Log", _
                            Optional percorsoLogPuntuale As String = "...\Log", Optional fullLog As Boolean = True, _
                            Optional puntualLog As Boolean = True)
       logCtrl.SaveLogAs(tempfile)
   End Sub
End Module
cMagnum.vb
Imports System.IO
Imports System.Data
Imports System.Xml
Public Class cMagnum
   Dim Log As IRuleLogger
	Public Sub New(log As IRuleLogger, datiConfigurazione(,) As Object,configPath As String )
		Me.Log = log
	End Sub
	Private ReadOnly Property calcolo_LT As Integer
		Get
			value = L - 2 * AMT
			Log.Trace("Valore di LT: " & value)
			Return value
		End Get
	End Property
End Class
The logger works perfectly on the class cMagnum, but not in the module mLog.
I get the error: "Object reference not set to an object instance."
This is only an example but the main concepet is that i need to create some "module" that can be recalled inside other classes as isn't possible to call a class inside another class as far as i know, and obviously i need to use the logger inside them.
I hope I have been as clear as possible.
