11-08-2023
03:32 AM
- Mute
- Permalink
- Report
11-08-2023
03:32 AM
Here i've the code with highlightset : the core issue :
'oHSet.Remove(StartFace)
If you add it again, it don't Highlight,....
so the solution is to clear it first, and make the 'new' set again.
oHSet.Clear For Each _face As Face In FaceList oHSet.AddItem(_face) Next
here is full code, 2 options , with color override or with highlight
Sub main Dim _inv As Inventor.Application = ThisApplication Dim PartDoc As PartDocument = ThisDoc.Document Dim oHSet As HighlightSet = PartDoc.CreateHighlightSet() oHSet.Clear ' Dim oTG As TransientObjects = _inv.TransientObjects ' Dim oDocAssets As Assets = PartDoc.Assets ' Dim oAppearanceHighlightRed As Asset = GetOrCreateAsset(oDocAssets, "New HighlightRed") ' Dim ColorHighlightRed As ColorAssetValue = oAppearanceHighlightRed.Item("generic_diffuse") ' ColorHighlightRed.Value = oTG.CreateColor(255, 0, 0) ' red Dim oStartFace As Face Dim FaceList As New List(Of Face) While True oStartFace = _inv.CommandManager.Pick(Inventor.SelectionFilterEnum.kPartFaceFilter, "Fläche anwählen + ""Esc"" bestätigen.") ' If nothing gets selected then we're done If oStartFace Is Nothing Then Exit While If FaceList.Count = 0 Then FaceList.Add(oStartFace) 'if crtl is pressed and listCount =0, we see crtl press as user fault, dont look 'oStartFace.Appearance = oAppearanceHighlightRed oHSet.AddItem(oStartFace) ElseIf Not FaceList.Contains(oStartFace) Then If Not System.Windows.Forms.Control.ModifierKeys = System.Windows.Forms.Keys.Control Then FaceList.Add(oStartFace) oHSet.AddItem(oStartFace) 'oStartFace.Appearance = oAppearanceHighlightRed End If Else 'contains If System.Windows.Forms.Control.ModifierKeys = System.Windows.Forms.Keys.Control Then FaceList.Remove(oStartFace) 'oStartFace.AppearanceSourceType = AppearanceSourceTypeEnum.kBodyAppearance 'oHSet.Remove(StartFace) same behavior off your code oHSet.Clear For Each _face As Face In FaceList oHSet.AddItem(_face) Next End If End If End While If FaceList.Count = 0 Then Exit Sub 'Area calculation Dim AreaCache As Double = 0 For Each oFace As Face In FaceList AreaCache = AreaCache + oFace.Evaluator.Area Next If Not AreaCache = o Then AreaCache = Math.Round(AreaCache * 100, 1) MsgBox("Area : " & AreaCache & "mm²") End If oHSet.clear 'reset highligt ' For Each oFace As Face In FaceList ' oFace.AppearanceSourceType = AppearanceSourceTypeEnum.kBodyAppearance ' 'other options to reset easy : kComponentOccurrenceAppearance,kDefaultAppearance,kFeatureAppearance,kMaterialAppearance,kPartAppearance ' Next End Sub 'Function GetOrCreateAsset(ByVal assets As Assets, ByVal assetName As String) As Asset ' Try ' Return assets.Item(assetName) ' Catch ex As Exception ' ' Het asset bestaat nog niet, dus maken we er een aan ' Return assets.Add(AssetTypeEnum.kAssetTypeAppearance, "Generic", "HighlightRed", assetName) ' End Try 'End Function
